Pressure inlet boundary conditions for open channel flows |
July 10, 2007, 12:41 |
Dear all,
I try to use Ope
JZ
Rep Power: 17 |
Dear all, I try to use OpenFOAM to study discharge capacity problem of a spillway. My problem is schematized as follow figure: In this 2D problem, the upstream water level, gate opening and downstream water are known. However, the discharge capacity is unknown, so that the inlet velocity can not be given. I setup the inlet and outlet with pressure inlet/outlet boundaries. But during the simulation, deta_T became smaller and smaller then equal 0! The simulation failed!! for 1~2 : pressureInlet gamma = fixedValue=1 velocity=pressureinletVelocity (I used 0) pd=fixValue (rho*H=constant or 0, both didn't work!) for 2~3 : pressureInlet gamma = fixedValue=1 velocity=pressureinletVelocity (I used 0) pd=fixValue (=0) for 4~5 pressureOutlet gamma= zeroGradient velocity=zeroGradient pd= fixedValue=0 for 5~6 pressureOutlet gamma= zeroGradient velocity=zeroGradient pd= fixedValue=0 However, I can do the simulation well with velocity inlet BC for 1~2 : Inlet gamma = fixedValue=1 velocity=inletVelocity pd=zeroGradient for 2~3 : Inlet gamma=fixedValue =0 velocity=inletVelocity=0 pd = zeroGradient for 4~5 PresureOutlet gamma=fixedValue =1 velocity=zeroGradient pd=zeroGradient for 5~6 PressureOutlet gamma=fixedValue=0 velocity=zeroGradient pd=zeroGradient It is highly appreciated for any comments or suggestion! Best Regards! Jack |
July 10, 2007, 14:36 |
I forgot to mention that I use
JZ
Rep Power: 17 |
I forgot to mention that I used interFoam solver.
Thanks, Jack |
August 4, 2010, 15:24 |
rlobosco
Rep Power: 17 |
Hello Jack,
I have a similar case. Can you tell me how you solve the problem? with best regards, rlobosco |
October 21, 2012, 15:10 |
Siamak Gharahjeh
Rep Power: 14 |
it seems like it's an outdated post, yet I know the answer, so contact me in case u need.
October 6, 2016, 09:51 |
Christian Fri
Rep Power: 17 |
Hi Siamak. What is the answer that you have for this problem?
Thanks! |
December 6, 2018, 12:00 |
Akshay Patil
Rep Power: 11 |
I am working on a similar problem, would be great if you could share the boundary conditions for U, p_rgh and alpha.water for this particular case. Thank You!
Open Channel Flow - Setting Boundary Conditions | Christine Sindelar | FLUENT | 6 | June 6, 2011 05:11 |
Open Channel Boundary Conditions via journal | Matteo | FLUENT | 0 | January 21, 2008 12:05 |
boundary conditions for open rectangular channel | pavan | FLUENT | 1 | March 6, 2007 16:46 |
boundary conditions in open rectangular channel | surya | FLUENT | 0 | March 5, 2007 01:06 |
open channel flow boundary conditions | yan | FLUENT | 0 | July 5, 2005 00:36 |
