How to iterate over all cells in decomposed mesh
Like Tree1Likes
  • 1 Post By gschaider
Old   October 23, 2007, 07:08
Default Hi everybody, Could someone
Thomas Jung
tehache is on a distinguished road
Hi everybody,
Could someone give me a hint on how to iterate over all cells of a decomposed mesh?
After naively using it for quite some time, I just found out that mesh.cells() gives me only the cells of one partition
Thank you!
Thomas
tehache is offline   Reply With Quote
Old   October 23, 2007, 08:14
Default Hi Thomas! That's the whole
Assistant Moderator
Bernhard Gschaider
Hi Thomas!
That's the whole point of parallelizing: every processor is responsible for "his" cells. If one processor could loop over all cells it would no longer be parallel.
What do you want to do? If it is something like counting cells with a specific property (that's one of the reasons why you might want to do this), then you should do it as usual and use something like
reduce(cnt,sumOp<label>());
to calculate the sum over all processors and distribute it to all processors
Bernhard
rajibroy likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 23, 2007, 08:44
Default Hi Bernhard, Actually, I wa
Thomas Jung
Hi Bernhard,
Actually, I was looking for a cell at a specific location to set a reference value there (fvMatrix::setReference).
I think I ran into a trap with that idea ... now apperently every processor is setting reference at a different cell..
Isn't there some way, even doing communication, to globally find a cell?
Just tried findNearestCell(), but seems to work also ony within one processors cells...
Old   October 23, 2007, 10:26
Default Hi Thomas! Something like t
Assistant Moderator
Bernhard Gschaider
Hi Thomas!
Something like this?
label cellI=mesh.findCell(location);
if(cellI>=0) {
matrix.setReference(cellI,value);
That'd set the reference only on the processor that has the cell in question, I guess.
Bernhard
Old   October 23, 2007, 11:06
Default Thx a lot! Thats it. And s
Thomas Jung
Thx a lot!
Thats it.
And so easy.... shame on me
Reconstruction of decomposed dynamic mesh cases david OpenFOAM Post-Processing 2 January 9, 2009 08:19
Empty cells in mesh Nikolaos FLOW-3D 2 October 22, 2008 00:17
RAM necessary for a 6 million cells hex mesh Antoine FLUENT 2 September 4, 2008 11:13
mesh with 804 cells.. nicolas FLUENT 6 September 24, 2007 07:14
[OpenFOAM] ParaFoam OF 14 decomposed cases philippose ParaView 4 April 18, 2007 06:17
