December 4, 2007, 12:40 |
Dear OpenFOAM uses and Develop
Rep Power: 18 |
Dear OpenFOAM uses and Developers
I request the forum users to shed some light on the details of how MULES works. Please share the information if anybody is aware of it. I looked into the code and this is what it contains: 1) overloaded function templates for --> explicitSolve - bounds can be supplied as the function argument; --> explicitSolve01 - for a scalar bounded between 0 and 1; --> implicitSolve01 - for a scalar bounded between 0 and 1; and a function template for --> limiter InterFoam uses the MULES solver to solve for the volScalarField gamma and calls MULES::explicitSolve01(gamma, phi, phiGamma). This eventually calls the function template template<class> void Foam::MULES::explicitSolve ( volScalarField& psi, const surfaceScalarField& phi, surfaceScalarField& phiPsi, const SpType& Sp, const SuType& Su, const scalar psiMax, const scalar psiMin ) with Sp = zero Su = zero psiMax = 1.0 psiMin = 0.0 Could anybody please comment what does template arguments: class SpType, class SuType stand for? Thanks in advance Jaswinder |
November 13, 2012, 05:36 |
#2 | |
Rep Power: 15 |
I think they are representing eventual source terms in the advection equation. There is even this possibility :
void Foam::MULES::explicitSolve ( const RhoType& rho, volScalarField& psi, const surfaceScalarField& phi, surfaceScalarField& phiPsi, const SpType& Sp, const SuType& Su, const scalar psiMax, const scalar psiMin ) How can I call this special MULES function (I need to provide both source terms and rho) ? I do : Quote:
Cheers, J |
November 13, 2012, 07:49 |
Rep Power: 15 |
yeah, I got it. it was because I should have written geometricOnesField() in place of OneField().
Thanks ! |
November 21, 2012, 09:56 |
Santiago Marquez Damian
Rep Power: 24 |
Hi Jaswinder, how you doing? MULES is an Flux Corrected Transport explicit solver for hyperbolic equations. Its implementation mostly follow the ideas of Zalesak limiter but the 's are calculated iteratively. I'm going to give some details in my thesis soon but that's the basic idea.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
November 17, 2020, 03:30 |
InterFoam learning material/sources
Hey Jaswi,
I am new entry in this OpenFOAM interFoam solver learners list. Can you share some notes and ideas with me regarding VOF treatment, flow through porous media and other programming aspects in OpenFOAM. my email id is : singhrohitace4@gmail.com |
June 21, 2022, 09:46 |
jitendra
Rep Power: 13 |
Hi Jaswinder,
I have just started learning the interFoam Solver in OpenFoam V9. I would be very grateful if you could send me some notes. my email id is; jitendra.patel5789@gmail.com Thank you in advance Regards, Jitendra |
About interFoam solver | zou_mo | OpenFOAM Running, Solving & CFD | 129 | December 2, 2019 06:39 |
Wmake problem interFoam solver | feijooos | OpenFOAM Running, Solving & CFD | 4 | December 8, 2008 12:01 |
DICPCG solver in interFoam | m9819348 | OpenFOAM Running, Solving & CFD | 1 | September 20, 2007 14:10 |
About interfoam solver | qiu | OpenFOAM Running, Solving & CFD | 0 | May 6, 2007 23:48 |
Need documentation for interFOAM solver | mer | OpenFOAM Running, Solving & CFD | 5 | May 31, 2006 13:22 |
