How can I add a new wall function
Like Tree4Likes
  • 1 Post By imano
  • 3 Post By eugene
Old   May 3, 2005, 04:37
Default Hello, I want to simulate a
Masashi IMANO
imano is on a distinguished road
I want to simulate a flow around a square prism exposed with a rough-wall turbulent boundary layer. For saving a calculation time, I want to use the log-law wall function with a roughness length instead of putting appropriate rougness blocks on the ground exactly.
Log-law wall function with a roughness length:
Uw/U*=ln(hw/z0)/kappa + A
where,
z0: roughness length
Uw: velocity near the ground
U*: friction velocity
hw: height from the ground
kappa, A: parameters
This is a my question.
[Q] How can I add a new wall function like this?
Thanks,
Masashi IMANO
shincoast likes this.
imano is offline   Reply With Quote
Old   May 3, 2005, 07:14
Default At the moment, wall functions
Eugene de Villiers
eugene is on a distinguished road
At the moment, wall functions are hardwired into the RANS turbulence models. To add a new wall function, you would have to copy an existing turbulence model and insert your new wall function where appropriate.
Example: kEpsilon model src/turbulenceModels/incompressible/kEpsilon/kEpsilin.C
line 88 = # include "wallViscosityI.H"
The "wallViscosityI.H" can be found here:
src/turbulenceModels/incompressible/wallFunc
So copy "wallViscosityI.H" to "roughWallViscosityI.H", modify it as required and include it in a copy of the turbulence model you wish to use. If you are feeling a bit adventurous, making the wall function selectable via a dictionary entry in the turbulenceProperties file would be more elegant.
solefire, kiddmax and songwukong like this.
eugene is offline   Reply With Quote
Old   May 3, 2005, 07:15
Default Are you running LES or RANS?
henry is on a distinguished road
Currently LES wall-functions are run-time selectable and it is easy to add new types but RANS wall-functions are not. I have thought about trying to make RANS wall-functions run-time selectable but have not yet come up with an elegant solution. If you would like to change the current RANS implementation you will find them in
OpenFOAM-1.1.1/src/turbulenceModels/compressible/wallFunc
for incompressible flow and in
OpenFOAM-1.1/src/turbulenceModels/compressible/wallFunc
for compressible flow.
henry is offline   Reply With Quote
Old   May 4, 2005, 04:18
Default Sorry, I forgot to mention abo
Masashi IMANO
Sorry, I forgot to mention about my calculation setup's detail.
1. I'm running high-Re RANS.
2. I need to apply the rough wall function only to a ground and other walls
should be calculated with normal slip wall function. So I would like
to change wall functions whether a wall is a ground or not.
Since I'm beginner about both OpenFOAM and C++ language;;,
I would like to copy and modify the wall function sources directly,
but I still need to switch wall functions with using information of
the wall.
[Q] How can I switch wall functions according to wall's
information(name?) in RANS wall function sources?
Thanks for your advice,
Masashi IMANO
Old   May 4, 2005, 04:36
Default You could add a test for the p
You could add a test for the patch name to the code in
and use your rough wall function on some wall patches and the original form on the rest.
Old   May 4, 2005, 04:46
Default Thanks. I will add a switch to
Masashi IMANO
Thanks. I will add a switch to the code you advised.
BTW how can I obtain OpenFOAM-1.1.1?
I could not find out the new release.
Thanks in advance,
Masashi IMANO.
Old   May 4, 2005, 05:06
Default OpenFOAM-1.1.1 is not quite re
OpenFOAM-1.1.1 is not quite ready for release yet, in fact it will go out as OpenFOAM-1.2 as it includes a substantial number of developments. OpenCFD will release it as soon as possible.
Old   January 22, 2006, 12:39
Default Hi, I´m also trying to implem
David Segersson
segersson is on a distinguished road
I´m also trying to implement rough wall functions (with non-uniform roughness...). Is it necessary to make changes anywhere else in the code, besides in the turbulence model, to include roughness effects (e.g. in the velocity b.c.)?
Masashi, have you made any progress in your implementation? In that case, it would probably help me a lot if you could post your code here or in the Wiki.
Regards
David
segersson is offline   Reply With Quote
Old   January 23, 2006, 00:18
Default Hi, David! I actually imple
Masashi IMANO
Hi, David!
I actually implemented rough wall functions, but my implementation couldn't handle non-uniform roughness and
was very ad-hoc like this:
src/turbulenceModels/incompressible/wallFunc/wallViscosityI.H:
if (yPlus > yPlusLam_)
if ((curPatch.name().count('~'))==2) {
nutw[facei] =
nuw[facei]
*(yPlus*kappa_.value()/(log(y_[patchi][facei]/z0_.value())) - 1.0);
} else if ((curPatch.name().count('^'))==2) {
nutw[facei] =
nuw[facei]
*(1.0/alpha_.value() - 1.0);
} else {
nutw[facei] =
nuw[facei]
*(yPlus*kappa_.value()/log(E_.value()*yPlus) - 1);
So I'm afraid my code would not help you...
Masashi,
Old   February 27, 2006, 16:52
Default Thanks Masashi, I'm not famil
David Segersson
Thanks Masashi,
I'm not familiar with the "wall viscosity" concept. Could you explain how you go from your wall-function for velocity to your implementation in wallViscosityI.H?
Also, since your formulation of a rough wallfunction differ from the one used in other codes e.g. Fluent, which uses Ks "sand grain roughness" to describe the roughness length, it would be interesting to know if you have evaluated the results from your wall-function somehow.
Regards
David
Old   February 27, 2006, 23:29
Default Dear David, Actually I impl
  #11
Masashi IMANO
Dear David,
Actually I implemented the log-law wall function with roughness length,
but there was little difference between a calculation result with the
implemented roughness wall and that with the original smooth wall.
As I had no time for finding out the reason at that time, I switched
the wall function from the roughness type to the original one.
So there is no evaluation about my implementation to show here...
Since my mother tongue is not English , it's difficult to explain the
"wall viscosity" concept here. So please consult guide books about
the numerical calculation of turbulent flow.
Regards,
Masashi
Old   February 28, 2006, 07:57
Default Wall viscosity is a pretty str
  #12
Eugene de Villiers
Wall viscosity is a pretty straightforward concept. Really it is just a "trick" to specify the wall shear stress via turbulent viscosity and the no-slip velocity boundary conditions.
So tau_w = nut_w * dU/dy
where tau_w can be found from some wall function and dU/dy is the wall normal derivative of velocity. See wallFunctions/wallViscosityI.H for details.
Old   December 13, 2007, 11:00
Default Hi all. I'm solving two phase
  #13
Hyunchang Lee
asteria is on a distinguished road
Hi all.
I'm solving two phase flow with twoPhaseEulerFoam and I want to implement new drag model. So according to your suggestions, I think it will be better to change the code which exists already(acutally it is schillerNeumann.C) rather than make new code for the drag model. I'm solving new fields, say moments and with those moments, got average diameter fields, let say, volScalarField D10. I want to use this D10 instead phasea_.d() in below code. How can I implement this diameter? I'm not used to C++, so any suggestion and help will be appreciated. Thanks in advance. have fun!!
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
Foam::tmp<foam::volscalarfield> Foam::SchillerNaumann::K
const volScalarField& Ur
) const
volScalarField Re = max(Ur*phasea_.d()/phaseb_.nu(), scalar(1.0e-3));
volScalarField Cds = 24.0*(scalar(1) + 0.15*pow(Re, 0.687))/Re;
forAll(Re, celli)
if(Re[celli] > 1000.0)
Cds[celli] = 0.44;
return 0.75*Cds*phaseb_.rho()*Ur/phasea_.d();
asteria is offline   Reply With Quote
Old   January 17, 2011, 06:19
Default roughness
  #14
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi all of foamers, i hope that you are well
i compiled the new solver with roughness( i modified simpleFoam & i used OF 1.5dev), but my question is how to change the related case to read this coeffs (Ks , Cs)? how to define the BC for this Coeffs?
best regards
desert_1250 is offline   Reply With Quote
Old   September 17, 2015, 09:53
Default how to make the new wall function
  #15
Xinguang Wang
JasonWang3 is on a distinguished road
hi
I find a guide on how to implement a turbulence model in openfoam:
http://www.tfd.chalmers.se/~hani/kur...lenceModel.pdf
However, I need to implement a new wall function, can I just follow the guide and make the new wall function?
Thanks a lot.
Jason
JasonWang3 is offline   Reply With Quote
Bug in wall function rolando OpenFOAM Bugs 7 June 8, 2007 05:51
wall function for low Re M. Essuri FLUENT 2 December 18, 2006 04:11
wall function Alex CFX 9 May 19, 2005 11:05
Does RSM use wall function? Sam Main CFD Forum 4 March 3, 2005 00:58
Wall function Min-Hua Wang CFX 4 July 5, 2002 13:13
