Moving interface patch using mesh subsets
Like Tree1Likes
  • 1 Post By lr103476
Old   January 10, 2008, 17:14
Default Hi everybody, To deal with
Frank Bos
lr103476 is on a distinguished road
Hi everybody,
To deal with very very large rotations, plunging rotating wing with angle of attach varying from +60 to -60 degrees, I developed a dynamicFvMesh library using fvSubsetMesh. This library creates two mesh subsets, following constant/polyMesh/sets and defines the motion on both. In such a way I define a mesh subset just around the wing which moves with the wing, and another outside it.
The motion of the innermesh is the result of motion definition of the wing patch leaving the outer mesh unchanged.
The motion of the outermesh is the result of motion definition of the interface patch. When the motion of the interface and the wing are the same the internal subset mesh moves undeformed with the wing.
2 problems/questions:
1) The problem is the interface. I have two subsets, how do I get the interface appear in /constant/polyMesh/boundary such that I can use that patch in dynamicFvMesh....
2) If the interface is present in /constant/polyMesh/boundary what boundary condition do I have to apply to U and p, since the flow needs to go though undisturbed.....
Regards and Thanks,
Frank
Regard, Frank
eskandari likes this.
Frank Bos
lr103476 is offline   Reply With Quote
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 10:42
domain interface for moving and deforming mesh chetan mundhe CFX 1 December 2, 2007 17:27
moving mesh grid interface Dieter FLUENT 6 March 23, 2006 07:54
VOF+patch+irregular interface shape luckyluke FLUENT 0 May 23, 2005 21:52
Moving interface Unal FLUENT 4 April 16, 2004 11:02
