Wall shear stress
Like Tree8Likes
  • 3 Post By andrewburns
  • 5 Post By dmoroian
Old   February 12, 2008, 18:16
Default Hello, I'm trying to figure ou
Andrew Burns
andrewburns is on a distinguished road
Hello, I'm trying to figure out the dimensions of openFoam's wall shear stress. I'm trying to compare the same mesh run for the same conditions in both fluent and openFoam, however when I use wallShearStress to find the stress on the openFoam case I get numbers that are much different to those from fluent.
I know fluent calculates wall shear stress in pascals, however when I look at the dimensions in the shear stress file generated by openFoam I see this:
[0 2 -2 0 0 0 0]
Wouldn't this mean the units for shear stress in openFoam are m^2/s^2 ? I don't understand how this can be converted to pascals for comparison purposes.
For an idea of the differences I'm talking about, fluent reports the maximum shear stress as 14 pascals, while openFoam reports it as 53.6.
Luttappy, MaySea and sourav90 like this.
andrewburns is offline   Reply With Quote
Old   February 13, 2008, 02:44
Default For an incompressible flow, al
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
For an incompressible flow, all the equations are divided with density. If you divide [Pa] with r, it should go like this:
Pa/r = N/m2/kg/m3 = kg*m/s2/m2/kg/m3 = m2/s2
I hope this is helpful!
Dragos
dmoroian is offline   Reply With Quote
Old   February 13, 2008, 17:40
Default Thanks that's perfect. I thoug
Andrew Burns
Thanks that's perfect. I thought it would be something like that but I wasn't able to work out if it made sense dimensionally.
Old   November 4, 2019, 05:25
Pedro Ramos
pedroxramos is on a distinguished road
is it the same in case of a turbulent flow?
because here they make a difference between laminar and turbulent:
http://aboutcfd.blogspot.com/2017/05...-openfoam.html
pedroxramos is offline   Reply With Quote
How to get the wall shear stress by UDF Chen Fangzhi FLUENT 3 November 11, 2014 07:03
wall shear stress brad Main CFD Forum 1 November 3, 2005 17:37
Shear stress at wall John FLUENT 0 September 21, 2005 09:27
UDF for wall shear stress Bastian FLUENT 0 July 21, 2004 05:52
wall shear stress lingo FLUENT 2 June 2, 2003 04:40
