Problem with fixedGradient BC
Like Tree1Likes
  • 1 Post By mike_jaworski
Old   February 26, 2008, 16:08
Default Hello, When I try to set BC
kar
Kārlis Repsons
kar is on a distinguished road
When I try to set BC type fixedGradient:
boundaryField
walls
type fixedGradient;
value uniform 0;
in 0/T file for temperature, after executing my solver I get this:
--> FOAM FATAL IO ERROR : keyword gradient is undefined in dictionary "/home/cpp/OpenFOAM/cpp-1.4.1/run/caurule/PUT/0/T::walls"
How should I define it or what else could be wrong?
K.
kar is offline   Reply With Quote
Old   February 26, 2008, 16:19
Default Karlis, The problem is ind
Michael Jaworski
mike_jaworski is on a distinguished road
Karlis,
The problem is indicated in the error message: keyword gradient is undefined.
The fixedGradient boundary condition should look like this:
boundaryField
walls
type fixedGradient;
gradient uniform 0;
i.e. there's a "keyword" of "value" used with fixedValue and a "keyword" of "gradient" used with fixedGradient BCs respectively.
Good luck,
Mike J.
sbusmayer likes this.
mike_jaworski is offline   Reply With Quote
Old   February 27, 2008, 02:42
Default Funny, right? http://www.cfd-o
kar
Kārlis Repsons
Funny, right?
Where I could find that in code? find gives me a lot about "fixedGradient".
Old   February 27, 2008, 03:07
Default Karlis, In order to answer
Michael Jaworski
Karlis,
In order to answer your question, I'd have to have a lot more knowledge of OpenFOAM than I currently do. I'm still a newbie as well. I believe that it'll be in the neighborhood of this file:
http://foam.sourceforge.net/doc/Doxy...hField_8H.html
Regards,
Mike J.
Old   March 8, 2008, 13:42
Default Hi Karlis, The information
Ola Widlund
olwi is on a distinguished road
Hi Karlis,
The information you needed is actually in the User's Guide. See Table 6.3 of Section 6.2.3.
In this particular case, the answer was in the written documentation, but that is admittedly not always the case with an open-source project like OpenFOAM. Still, I think OpenFOAM is one of the very few CFD codes that can crasch and give you a useful error message! In this case that the keyword "gradient" was missing...
I use Fluent more often than OF, and I assure you that the error messages I get there are completely useless. Most of the time the process just dies on me...
Good foaming!
/Ola
olwi is offline   Reply With Quote
Old   April 22, 2015, 21:06
Juan David Rodriguez P
JuanRodriguez is on a distinguished road
Hi, Karlis.
Why would you use a fixedGradient of value 0 when there is the zeroGradient b.c.?
Perhaps that old version of OF didn't contain zeroGradient.
If the reason is more complex please let me know.
Thank you.
JuanRodriguez is offline   Reply With Quote
FixedGradient Boundary Condition shrina OpenFOAM Running, Solving & CFD 4 August 22, 2019 12:08
FixedGradient BC update stefan82 OpenFOAM Running, Solving & CFD 4 April 28, 2009 04:10
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 10:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 08:45
problem in solving "wave generation" problem san FLUENT 2 April 4, 2006 00:37
