NuSGsWallFunction declaration type
Like Tree1Likes
  • 1 Post By eugene
Old   September 21, 2006, 06:29
Default Hello, I want to use a SGS
anne dejoan
anne is on a distinguished road
I want to use a SGS model + wall function.
I have read in a threat that to do so you have to
declare "nuSgsWallFunction" as type BC for nuSgs.
However, while doing this, I have the following error message when runninf the application:
I use openFoam 1.3 version.
How should it be declared so taht it wokds ?
--> FOAM FATAL IO ERROR : keyword value is undefined in dictionary "/home/anne/OpenFOAM/anne-1.3/run/OBSTACLE_HIGH_RE/0/nuSgs::bottomWall"
file: /home/anne/OpenFOAM/anne-1.3/run/OBSTACLE_HIGH_RE/0/nuSgs::bottomWall from line 245801 to line 245801.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 152.
FOAM exiting
Thanks you
anne
anne is offline   Reply With Quote
Old   September 21, 2006, 06:52
Default You need to add a value entry
Eugene de Villiers
eugene is on a distinguished road
You need to add a value entry to your nuSgsWallFunction boundary condition, like so:
bottomWall
type nuSgsWallFunction;
value uniform 1e-10;
Most boundary conditions require such a placeholder value entry even though the initial specification is not important. It is simply a result of the way the boundary class is derived from its base type.
solefire likes this.
eugene is offline   Reply With Quote
Old   September 21, 2006, 11:10
Default thanks , it runs now Ann
anne dejoan
thanks ,
it runs now
Anne
Old   September 22, 2006, 05:00
Default Hi again, I would like just
anne dejoan
Hi again,
I would like just some clarification:
when using LES+wall function,
Is the correct way to apply a fixed zero type BC for
U ?
Anne
Old   September 22, 2006, 05:28
Default Yes, wall functions are applie
Eugene de Villiers
Yes, wall functions are applied to the velocity field via an enhanced viscosity.
tau_w = (nu + nu_w) * du/dn_w
where the appropriate nu_w is calculated using the wall function.
Old   April 14, 2008, 15:35
Default Dear All, I also try to do
Thomas Gallinger
thomas is on a distinguished road
Dear All,
I also try to do LES with wall functions.
My problem is, that if I apply the type "nuSgsWallFunction" to a wall patch, as mentioned above, I get the error message: This is an unknown patch field, if I try to decompose the case.
If I run it without decomposition the solver starts and doesn't complain about the patch.
In the .OpenFOAM/controldict the switch disallowDefaultFvPattchField is set to 1.
I'm using the 1.4.1-dev version of Foam.
So I'm not shure if wall functions are applied or not. Can someone help?
Thanks in advance
Thomas
thomas is offline   Reply With Quote
Operator declaration in Thermophysical library lena OpenFOAM Running, Solving & CFD 0 March 12, 2009 10:47
Array declaration kdarc OpenFOAM Running, Solving & CFD 0 August 24, 2007 00:21
FORTRAN variable declaration sriram Main CFD Forum 3 October 22, 2005 07:08
variable declaration zheh Phoenics 0 September 7, 2001 23:58
Boundary declaration Tadiwos CFX 4 August 22, 2001 10:12
