June 16, 2008, 05:23 |
Hi every:
i am interested in
Hi every:
i am interested in the SST model,but i always a get a strange result --in terms of a "streak of higher value F1 appearing away from the wall in the outer regions of the boundary layer" whenever i modify the mesh.it appears as it is of "SST",and according the help of my friend,i turn to the paper of A.Herllsten (AIAA98-2554),according to the paper "a better behavior is obtained when CDkwmin is made proportional to the maximum value of cross-diffusion term detected in the flow field" so how can i get the "maximum value of cross-diffusion term detected in the flow field" by modify the basic SST model in the OF?,is there any function to get the max value of the flow field? yours wayne thanks! |
June 16, 2008, 05:30 |
Hi Wayne,
To get the maximum
Dragos
Rep Power: 20 |
Hi Wayne,
To get the maximum value of a field, you can use max(field). Dragos |
June 16, 2008, 05:44 |
And to add to Dragos' note, I
Niels Gjoel Jacobsen
Rep Power: 37 |
And to add to Dragos' note, I can recommend the Programmers Guide pp 23-25, which gives a list of algebraic tensor operations.
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
June 16, 2008, 12:22 |
gMax could help!?
label buf
Fabian Braennstroem
Rep Power: 19 |
gMax could help!?
label buffmin = findMin(scalarFlds1); Info << "max: " << gMax(scalarFlds1[buffmin].internalField()) << endl; |
June 17, 2008, 06:07 |
Hi thanks;
i have made some m
Hi thanks;
i have made some modification of SST model : *---------------------------------------------------------------------------*/ #include "kOmegaSST.H" #include "addToRunTimeSelectionTable.H" #include "wallFvPatch.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { namespace turbulenceModels { // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // defineTypeNameAndDebug(kOmegaSSTRC, 0); addToRunTimeSelectionTable(turbulenceModel, kOmegaSSTRC, dictionary); // * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * * // tmp<volscalarfield> kOmegaSSTRC::F1(const volScalarField& CDkOmega,const volScalarField& CDkOmegalim) const { volScalarField CDkOmegaPlus = max ( CDkOmega, CDkOmegalim );//**modification** use the CDkOmegalim instead of 1.0e-10 volScalarField arg1 = min ( .... } tmp<volscalarfield> kOmegaSSTRC::F2() const { ... } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // kOmegaSSTRC::kOmegaSSTRC ..... // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // tmp<volsymmtensorfield> kOmegaSSTRC::R() const { .... } tmp<fvvectormatrix> kOmegaSSTRC::divR(volVectorField& U) const { .... } bool kOmegaSSTRC::read() { .... } void kOmegaSSTRC::correct() { transportModel_.correct(); if (!turbulence_) { return; } turbulenceModel::correct(); if (mesh_.moving()) { y_.correct(); } volScalarField S2 = mag(symm(fvc::grad(U_))); volScalarField OMEGA2 = mag(skew(fvc::grad(U_))); volScalarField G = nut_*2*S2*OMEGA2;//**modification** Production limitation of Kato and Launder //# include "kOmegaWallFunctionsI.H" volScalarField CDkOmega = (2*alphaOmega2)*(fvc::grad(k_) & fvc::grad(omega_))/omega_; //**modification** define the limitation of the CDkw by the maximum value of cross section term in the flow field (AIAA98-2554) volScalarField CDkOmegalim = 1.0e-8*gmax((2*alphaOmega2)*(fvc::grad(k_) & fvc::grad(omega_))/omega_); //**modification** get the F1 from CDkOmega and CDkOmegalim volScalarField F1 = this->F1(CDkOmega,CDkOmegalim); //**modification** rotation and curve modification of SST model by Richardeson number defined in the A.Hellsten`s paper(AIAA A98-32817 volScalarField Ri = mag(skew(fvc::grad(U_)))/mag(symm(fvc::grad(U_)))*(mag(skew(fvc::grad(U_)))/mag( symm(fvc::grad(U_)))-1); volScalarField F4 = pow(1+3.6*Ri,-1); // Turbulent frequency equation tmp<fvscalarmatrix> omegaEqn ( fvm::ddt(omega_) + fvm::div(phi_, omega_) - F4*::Sp(fvc::div(phi_), omega_) - fvm::laplacian(DomegaEff(F1), omega_) == gamma(F1)*2*S2*OMEGA2 - fvm::Sp(beta(F1)*omega_, omega_) - fvm::SuSp ( (F1 - scalar(1))*CDkOmega/omega_, omega_ ) ); omegaEqn().relax(); ..... } but when i do the wmake there is lots of error message + wmake libso incompressible Making dependency list for source file kOmegaSSTRC/kOmegaSSTRC.C SOURCE=kOmegaSSTRC/kOmegaSSTRC.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -IlnInclude -I. -I/home/waynezw0618/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/kOmegaSSTRC.o kOmegaSSTRC/kOmegaSSTRC.C:40: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:40: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:40: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:40: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:45: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:45: error: non-member function 'Foam::tmp<foam::geometricfield<double,> > Foam::turbulenceModels::F1(const Foam::volScalarField&, const Foam::volScalarField&)' cannot have cv-qualifier kOmegaSSTRC/kOmegaSSTRC.C: In function 'Foam::tmp<foam::geometricfield<double,> > Foam::turbulenceModels::F1(const Foam::volScalarField&, const Foam::volScalarField&)': kOmegaSSTRC/kOmegaSSTRC.C:59: error: 'betaStar' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:59: error: 'k_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:59: error: 'omega_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:59: error: 'y_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:60: error: 'nu' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:62: error: 'alphaOmega2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:70: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:70: error: non-member function 'Foam::tmp<foam::geometricfield<double,> > Foam::turbulenceModels::F2()' cannot have cv-qualifier kOmegaSSTRC/kOmegaSSTRC.C: In function 'Foam::tmp<foam::geometricfield<double,> > Foam::turbulenceModels::F2()': kOmegaSSTRC/kOmegaSSTRC.C:76: error: 'betaStar' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:76: error: 'k_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:76: error: 'omega_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:76: error: 'y_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:77: error: 'nu' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:88: error: 'kOmegaSSTRC' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:93: error: ISO C++ forbids declaration of 'kOmegaSSTRC' with no type kOmegaSSTRC/kOmegaSSTRC.C: In function 'int Foam::turbulenceModels::kOmegaSSTRC(const Foam::volVectorField&, const Foam::surfaceScalarField&, Foam::transportModel&)': kOmegaSSTRC/kOmegaSSTRC.C:94: error: only constructors take base initializers kOmegaSSTRC/kOmegaSSTRC.C:97: error: 'turbulenceModelCoeffs_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:114: error: 'mesh_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:121: error: 'runTime_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:142: error: 'a1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:142: error: 'k_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:142: error: 'omega_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:142: error: 'omegaSmall_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:142: error: 'U_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:145: warning: no return statement in function returning non-void kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:150: error: 'kOmegaSSTRC' is not a class or namespace kOmegaSSTRC/kOmegaSSTRC.C:150: error: non-member function 'Foam::tmp<foam::geometricfield<foam::symmtensor<d ouble>, Foam::fvPatchField, Foam::volMesh> > Foam::turbulenceModels::R()' cannot have cv-qualifier kOmegaSSTRC/kOmegaSSTRC.C: In function 'Foam::tmp<foam::geometricfield<foam::symmtensor<d ouble>, Foam::fvPatchField, Foam::volMesh> > Foam::turbulenceModels::R()': kOmegaSSTRC/kOmegaSSTRC.C:159: error: 'runTime_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:160: error: 'mesh_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:164: error: 'k_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:164: error: 'nut_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:164: error: 'U_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:171: error: 'kOmegaSSTRC' is not a class or namespace kOmegaSSTRC/kOmegaSSTRC.C:171: error: non-member function 'Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::turbulenceModels::divR(Foam::volVectorField& )' cannot have cv-qualifier kOmegaSSTRC/kOmegaSSTRC.C: In function 'Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::turbulenceModels::divR(Foam::volVectorField& )': kOmegaSSTRC/kOmegaSSTRC.C:175: error: 'nuEff' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:181: error: 'kOmegaSSTRC' is not a class or namespace kOmegaSSTRC/kOmegaSSTRC.C: In function 'bool Foam::turbulenceModels::read()': kOmegaSSTRC/kOmegaSSTRC.C:183: error: cannot call member function 'virtual bool Foam::turbulenceModel::read()' without object kOmegaSSTRC/kOmegaSSTRC.C:185: error: 'turbulenceModelCoeffs_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:185: error: 'alphaK1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:186: error: 'alphaK2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:187: error: 'alphaOmega1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:188: error: 'alphaOmega2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:189: error: 'gamma1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:190: error: 'gamma2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:191: error: 'beta1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:192: error: 'beta2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:193: error: 'betaStar' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:194: error: 'a1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:195: error: 'c1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:196: error: 'Cmu' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C: At global scope: kOmegaSSTRC/kOmegaSSTRC.C:207: error: 'kOmegaSSTRC' is not a class or namespace kOmegaSSTRC/kOmegaSSTRC.C: In function 'void Foam::turbulenceModels::correct()': kOmegaSSTRC/kOmegaSSTRC.C:209: error: 'transportModel_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:211: error: 'turbulence_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:216: error: cannot call member function 'virtual void Foam::turbulenceModel::correct()' without object kOmegaSSTRC/kOmegaSSTRC.C:218: error: 'mesh_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:220: error: 'y_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:223: error: 'U_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:225: error: 'nut_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:230: error: 'alphaOmega2' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:230: error: 'k_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:230: error: 'omega_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:233: error: 'gmax' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:236: error: invalid use of 'this' in non-member function kOmegaSSTRC/kOmegaSSTRC.C:247: error: 'phi_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:248: error: '::Sp' has not been declared kOmegaSSTRC/kOmegaSSTRC.C:249: error: 'DomegaEff' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:251: error: cannot convert 'Foam::volScalarField' to 'double' for argument '1' to 'double gamma(double)' kOmegaSSTRC/kOmegaSSTRC.C:252: error: 'beta' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:265: error: 'omega0_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:273: error: 'DkEff' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:275: error: 'c1' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:275: error: 'betaStar' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:281: error: 'k0_' was not declared in this scope kOmegaSSTRC/kOmegaSSTRC.C:285: error: 'a1' was not declared in this scope make: *** [Make/linux64GccDPOpt/kOmegaSSTRC.o] error1 can you tell me what is wrong with it ? thanks yours wayne |
How to get Pressure field from velocity field | qunwuhe@hotmail.com | Main CFD Forum | 4 | October 14, 2007 08:38 |
Putting submesh field values into field on parent mesh | helmut | OpenFOAM Running, Solving & CFD | 2 | June 20, 2006 08:31 |
velocity field | Faiz Ahmed | Main CFD Forum | 0 | March 5, 2006 11:11 |
whole-field solution ? | rohit | Phoenics | 1 | February 3, 2005 13:13 |
field by field decomposition vs. component-wise | zhanglei | Main CFD Forum | 0 | January 5, 2001 10:06 |
