FOAM FATAL IO ERROR attempt to read beyond EOF
Like Tree6Likes
  • 3 Post By Hisham
  • 1 Post By neiht
  • 1 Post By Pier84
  • 1 Post By galoisati
Old   August 9, 2005, 04:57
Default Hello everybody. Just regis
unoder
Hello everybody.
Just registered for an account and am going through the tutorial in order to learn OpenFOAM and something about numerical fluid simulation. I hope you can help me with this problem:
At this moment I came to page 39, chapter 2.1.6.3. Foam is version 1.1 running on Suse linux 9.2.
I type in the command: "mapFields . cavityFine
/ . cavityGrade/ -consistent", but why do I then get the following error message?
------ begin -------
martin@linux:~/OpenFOAM/martin-1.1/run/tutorials/icoFoam> mapFields . cavityFine
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : mapFields . cavityFine/ . cavityGrade/ -consistent
Date : May 21 2005
Time : 23:32:15
Host : linux
PID : 11708
Root :
Case :
Nprocs : 1
Source: "." "cavityFine/"
Target: "." "cavityGrade/"
Create databases as time
Source time: 0.7
Target time: 0.7
Create meshes
Source mesh size: 1681 Target mesh size: 400
Consistently creating and mapping fields for time 0.7
interpolating p
--> FOAM FATAL IO ERROR : attempt to read beyond EOF
file: ./cavityGrade//0.7/p::internalField at line 30.
Function: ITstream::read(token& t)
in file: db/IOstreams/Tstreams/ITread.C at line: 70.
FOAM exiting
------ end -------
Best regards,
Martin Jørgensen
Old   August 14, 2005, 04:11
Default Hi there, Just for the arch
unoder
Hi there,
Just for the archive: I don't know what was wrong but overwriting the tutorials directory including subdirectories with the original files solved the problem.
Strange error message, IMO.
Best regards,
Martin Jørgensen
Old   June 21, 2008, 20:02
Default artin: I have the same issue
musaddeque hossein
musahossein is on a distinguished road
artin:
I have the same issue with parafoam as you did. When I try to view the cavity case mesh with parafoam in accordance with the openfoam tutorial documentation, I get the eof error. However, unlike your case, I am not being able to solve it by reloading the tutorial files. Any suggestions?
Thanks
Musa
musahossein is offline   Reply With Quote
Old   July 13, 2008, 03:28
Default I have the exact same problem.
Daniel Jessop
danj is on a distinguished road
I have the exact same problem...
danj is offline   Reply With Quote
Old   September 21, 2011, 16:36
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
This problem seems to arise when you use an older version input method in files for a newer version of OpenFOAM. Check that the way your data is written (or copy pasted from say a website) is consistent with your installed version file format (written like the examples)
holodeck10, aow and Turin Turambar like this.
Hisham is offline   Reply With Quote
Old   May 28, 2013, 07:42
QuocThien
neiht is on a distinguished road
i think wrong definition uniform or nonuniform scalar. it needs to add scalar value after
TeddyL likes this.
neiht is offline   Reply With Quote
Old   August 29, 2016, 04:45
Pierluigi Olmati
Pier84 is on a distinguished road
Try to check the format. Sometime I have this error when I forget " ; ".
Cheers,
Pierluigi
Santhosh91 likes this.
Pier84 is offline   Reply With Quote
Old   September 20, 2016, 06:47
Post same problem
Yingchen Cao
Yingchen is on a distinguished road
I had the same problem. I forgot the blank space in the dict file. So if you have the same problem, just pay attention to the format.
Yingchen is offline   Reply With Quote
Old   June 11, 2022, 22:00
Michael Jensen
mikethe1wheelnut is on a distinguished road
Looks to me like you have to do more than pay attention to the format. A lot of functionality that in principle should be there, isn't. For example, I've found that in some places, you can put a hard-coded number, but not a variable. I'll limit myself to documenting problems that are stopping me in my tracks.. ..well.. quick example:
        name    cs;
        type    cellSet;
        action  new;
        source  cylinderToCell;
        sourceInfo
            point1 (0 0 -100);
            point2 (0 0  100);
            centre (0 0 0);
            radius $cylinderRadius;
Those numbers after point1 and point2 and center? those can't be variables. oh, and "innerRadius" following radius doesn't do anything. that might be a .org vrs .com issue though..
mikethe1wheelnut is offline   Reply With Quote
Old   January 10, 2024, 06:57
atilla altintas
galoisati is on a distinguished road
I have solved a similar error by changing the fvSchemes file, default sheme from Gauss upwind to Gauss linear as below:
divSchemes
default Gauss linear;
div(phi,U) Gauss upwind;
div(phi,T) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
I hope it helps to someone.
R2P3 likes this.
galoisati is offline   Reply With Quote
Old   April 16, 2024, 04:03
bany
bany is on a distinguished road
Originally Posted by galoisati View Post
divSchemes
Hi, I met the same error.
The "default Gauss upwind;" does not work. However, "default Gauss upwind phi;" does work.
bany is offline   Reply With Quote
Old   October 20, 2024, 13:21
Teddy Liu
TeddyL is on a distinguished road
Maybe should pay attention to the comment syntax of the code, I once used "/*...*/" syntax to debug in my code, and it gave this error, but the "//" for comment is fine. (I used openfoam-v2212, it took me hours to figure that out) I hope this would do help for someone.
TeddyL is offline   Reply With Quote
Old   October 22, 2024, 19:32
William Peace
WJPeace1 is on a distinguished road
I've also had the same issue with v2312. This seems to happen anytime I change the divSchemes for some reason...
WJPeace1 is offline   Reply With Quote
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 11:06
[Commercial meshers] FOAM FATAL ERROR points deallocated hoerl OpenFOAM Meshing & Mesh Conversion 0 October 30, 2006 08:47
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 13:48
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 15:20
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 05:37
