Solving a Riemann problem in OpenFoam
Like Tree1Likes
  • 1 Post By pbohorquez
Old   July 13, 2008, 14:22
Default Hello I would like to write
srinath
srinath is on a distinguished road
Hello
I would like to write a Riemann solver for Euler's equations, as i have all the usual functions for calculating the intercell fluxes.
But i am unsure about how to implement it in openFoam.
I need to do the following
1)Loop over all internal faces
2)Find the 2 cells sharing a particular face
3)Extract values such as u,rho,p etc from these 2 cells and assign a flux to that face(after solving a Riemann problem)
But how would i do this in OpenFoam?
Just a couple of code snippets and some info on where to look in the source code should suffice.
None of the existing solvers, seem to do anything like this
Thanks
Srinath
srinath is offline   Reply With Quote
Old   July 14, 2008, 04:53
Default Did you have a look into g3dFo
Patricio Bohorquez
pbohorquez is on a distinguished road
Did you have a look into g3dFoam? I think this can help you.
g3dFoam: Implementing third order compressible flow solver for hexahedral meshes in OpenFoam, by Martin Olausson.
http://www.tfd.chalmers.se/~hani/kurser/OF_phD_2007/
songwukong likes this.
pbohorquez is offline   Reply With Quote
Old   July 15, 2008, 10:34
Default Thanks Patricio I will take
srinath
Thanks Patricio
I will take a look.
Srinath
Riemann problem shuo Main CFD Forum 5 July 9, 2009 14:28
Solving point implicit schemes in openFoam srinath OpenFOAM 2 October 13, 2008 01:50
2D Riemann problem ganesh Main CFD Forum 0 October 26, 2005 07:45
2D Riemann problem ganesh Main CFD Forum 9 October 3, 2005 09:09
Riemann Problem Valdemir Main CFD Forum 1 February 21, 2003 13:06
