PostChannel utility not working in OpenFoam 15 |
August 15, 2008, 00:49 |
Hi forum...
I was trying t
Nishant
Rep Power: 17 |
Hi forum...
I was trying to get the postchannel plots for the channel395 case in OF-1.5. Unfortunately postChannel utility has not been able to generate the Uf.xy, u.xy etc etc plots in OF-1.5. I noticed that instead of Umean, now OF-1.5 writes UMean (capital M) in every time directory. Also R file is not present in time directory. Is this error in postChannel utility because of that? I go through both the codes and find no difference. I am still looking into it but It will be helpful if someone can tell me fast. regards, Nishant
Thanks and regards, Nishant |
August 20, 2008, 23:14 |
can anyone take out some time
Nishant
Rep Power: 17 |
can anyone take out some time to comment on the above problem. I changed the postchannel utility with UMean instead of Umean.. and now the utility is complaining about R file not found.
Now the question is, why channeloodle utility is not writting R field??
May 5, 2009, 06:27 |
Leonardo Giampani Morita
Rep Power: 17 |
I have the same problem...after running the postChannel utility, no files are created...has somebody figured out what the cause of the problem is? Thanks, Leonardo |
May 6, 2009, 21:48 |
Daniel WEI (老魏)
Rep Power: 21 |
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
June 8, 2009, 05:44 |
Dr. Fabian Schlegel
Rep Power: 18 |
UPrime2Mean is not R I guess. Nevertheless you have to use UPrime2Mean to calculate the reynolds stresses.
June 8, 2009, 06:29 |
Dr. Fabian Schlegel
Rep Power: 18 |
Allright I think the following, but this is just an assumption, not proved up to now:
R = average(u'_i u'_j) UprimeToMean = average(u_i u_j) An by this R becomes: R = average ( u'_i u'_j) = average(u_i u_j) - average(u_i) * average (u_j) (1) Edit: I found a working postChannel in the GIT repository. But I am still 99% sure, that R is not the same als Uprime2Mean, if R is the reynolds stress tensor. But I am not able to figure out where the calculation (see equation 1) is done so far. But I am not so familiar with C++, so it is a bit difficult for me to understand the source code :-/ Please correct me if I am wrong. Last edited by fs82; June 8, 2009 at 11:34. Reason: new awarenesses |
June 9, 2009, 06:32 |
Dr. Fabian Schlegel
Rep Power: 18 |
Mea culpa :-/ I went into the fieldAverage routines and checked the calculation of the reynolds stresses and I have to take back everything and state the opposite. OpenFoam calculates average(u_i u_j) but writes out everytime step average(u'_i u'_j). This is done by equation (1). But before calculation the new reynolds stress tensor equation (1) is used again to get average(u_i u_j) from average(u'_i u'_j). So everything is fine and you can use UPrimeToMean instead of R from former OpenFoam versions.
Sry, fs82 |
December 9, 2011, 14:11 |
FieldAveraging-Reynolds stress
#10 |
pooyan
Rep Power: 15 |
Hey guys,
I am trying to get Reynolds Stress Components for Lid driven cavity flow. By using fieldaveraging, I get 6 components for uprime2mean as written below UPrime2Mean:0 UPrime2Mean:1 UPrime2Mean:2 UPrime2Mean:3 UPrime2Mean:4 UPrime2Mean:5 My questions are that, are these components the Reynolds Stress tensor?! Which of these representing <uu>, <uv>, <vv> and etc?! Thanks |
December 11, 2011, 07:37 |
#11 |
Dr. Fabian Schlegel
Rep Power: 18 |
December 12, 2011, 15:36 |
#12 |
pooyan
Rep Power: 15 |
Thanks. I went through this website, but I could not get any help from that. Do you think these six components are Reynolds Stress tensor?!
I guess Uprime2Mean (0) is <uu> and Uprime2Mean (1) is <vv> |
December 13, 2011, 05:26 |
#13 |
Dr. Fabian Schlegel
Rep Power: 18 |
Alright, the site I suggested wasn't the best one to read. The best way is to try it out. I guess you have performed a test run and already have the field "UPrime2Mean". So do the following: "foamCalc components UPrime2Mean" in your foam case directory. This will provide you each component uu, vv, ww, uv, uw, vw in a separate file. Compare the values of your original symmTensor field to the ones in the files and you have the answer.
For my understanding UPrime2Mean represents more or less the Reynolds stresses. If you perform an LES you have: Mean Value + Fluctuations + Subgrid stresses = Instantaneous value and UPrime2Mean include for my understanding only the Fluctuations. In case of RANS I am not sure, but I think UPrime2Mean does not exist there (never tried a RANS), but you got an additional field named R, which represents the Reynolds stresses. May be one of the more advanced user could give you more information. kind regards, Fabian |
December 13, 2011, 17:58 |
#14 |
pooyan
Rep Power: 15 |
Thanks for your complete response. I do appreciate your help.
I will try those suggested ways. Best Wishes, |
January 17, 2012, 17:39 |
#15 | |
pooyan
Rep Power: 15 |
Fabian,
I tried to get access to the source code to check the calculation of UPrime2Mean. I went through fieldAverage.C and fieldAverage.H, but unfortunately I could not see the calculation of Uprime2Mean in those files. Where should I check that out? Thanks, Quote:
January 18, 2012, 06:26 |
#16 |
Dr. Fabian Schlegel
Rep Power: 18 |
You have to go to the follwing directory: <foampath>/OpenFOAM-1.6.x/src/postProcessing/functionObjects/field/fieldAverage/fieldAverage and everything is there. The calculation of the mean and Prime2Mean values could be found in fieldAverageTemplates.C after a quick look.
hope this helps, Fabian |
OpenFOAM Message Board Email notification stopped working | mbeaudoin | OpenFOAM Bugs | 3 | January 8, 2009 23:08 |
[Technical] Mathematical exact definition of mesh quality measures in OpenFOAM checkMesh utility | albcem | OpenFOAM Meshing & Mesh Conversion | 1 | October 31, 2008 05:12 |
PostChannel Utility in openfoam15 not working | nishant_hull | OpenFOAM Bugs | 0 | August 14, 2008 16:49 |
My OpenFoam stop working can anyone help please | qtian | OpenFOAM Running, Solving & CFD | 0 | February 19, 2008 17:55 |
OpenFOAM is working for this | nobody_ua | OpenFOAM Running, Solving & CFD | 4 | April 20, 2005 07:11 |
