BuoyantSimpleFoam Channel problem
Like Tree1Likes
  • 1 Post By mkraposhin
Old   August 11, 2008, 02:56
Default Hello, I do not think buoy
Prashant Ojha
prashant24983 is on a distinguished road
I do not think buoyantSimpleFoam is suitable for your application. Read more on boussinesqBuoyantFoam in the dev version. buoyantSimpleFoam uses the perfect gas equation to calculate the density of media, for your case with water, boussinesq approximation is most appropriate.
http://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/Op enFOAM-1.4.1-dev/applications/solvers/heatTransfer/boussinesqBuoyantFoam/
prashant24983 is offline   Reply With Quote
Old   August 11, 2008, 03:17
Default Helo,, use fixedFluxBuoyantP
Pawan
pawan is on a distinguished road
Helo,,
use fixedFluxBuoyantPressure boundary conditon for pd .
pawan is offline   Reply With Quote
Old   August 11, 2008, 11:10
Default Hi, thanks for the answer.
tian's Avatar
Tian
tian is on a distinguished road
thanks for the answer. Prashant, I use air as fluid in the channel. The channel is open in the top and buttom (inlet and outlet). So, my task is to find out how many fluid is driven because of hot cylinder inside (buoyancy flow) near the bottom.
Yesterday, I copied "boussinesqBuoyantFoam" in OF 1.5 and wmake it. It is working. I also compiled "calcMassFlow" to see how many fluid goes through my inlet and outlet (3D case).
It is difficult to explain. So I found a small video and a picture. Maybe you can have a look and see:
http://www.building-engineering.de/OpenFOAM/t.mpeg
http://www.building-engineering.de/O...xamples001.png
I am not sure about the boundary conditions.
Inlet: I do not know about the velocity
Outlet: I do not know about the velocity
Hot pipe inside: Temperature constant
Air inside: Temperature at the beginning I know
wall: adiabatic
I hope you can understand my poor englisch :-)
I also will try out "fixedFluxBuoyanPressure"
Thanks for help
Bye
Tian
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance.
tian is offline   Reply With Quote
Old   August 28, 2008, 07:38
Default Hi, Until now I not find a
tian's Avatar
Tian
Until now I not find a solution for my problem. I am confused why "buoyantSimpleFoam" need at time 0 the values for "p" and "pd"? The version OF 1.4.1 only need p. How I have to setup a outlet and inlet at time 0? Velocity for inlet and zeroGradiet for p... Outlet zeroGradient for u and fixedValue for p but pd, I have not an idea about it... Can some body give me advice? Thanks a lot.
Bye
Thomas
Old   September 17, 2008, 08:59
Default you can try fixedFluxBuoyantPr
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
you can try fixedFluxBuoyantPressure for p and
fluxCorrectedVelocity for U
i am also interested in natural convection simulation, can you post image of your study?
what BC's are using for turbulence model?
mkraposhin is offline   Reply With Quote
Old   September 17, 2008, 09:43
Default Hi, thanks Kraposhin, I can
tian's Avatar
Tian
thanks Kraposhin, I can send to your email some screenshot.
I change my solver to the boussinesqBouyantSimpleFoam Solver for my study. The application also use RAS turbulence model.
Bye
Thomas
Old   September 17, 2008, 10:55
Default Hi, I tried the BC's fixedF
tian's Avatar
Tian
I tried the BC's fixedFluxBuoyantPressure with fluxCorrectedVelocity for U but there are some errors if I start the solver. Can you explain me more about how I can use this BC's?
Thanks a lot.
Thomas
Old   September 18, 2008, 05:50
Default ok, my e-mail is mkraposhin@in
mkraposhin's Avatar
Matvey Kraposhin
ok, my e-mail is mkraposhin@inbox.ru
the difference between boussinesqBouyantSimpleFoam and buoyantSimpleFoam is only that boussinesqBouyantSimpleFoam uses simplified boussinesq assumption. Both solvers can be used for solving natural convection tasks. What RAS model are you using? How do you calculate initial turbulence parameters on boundaries and in internal domain?
about BC's
fixedFluxBuoyantPressure is used to setup full pressure field on boundaries (p+r*g*h)
fluxCorrectedVelocity can be used when pressure field is already known. Another way, i think, is to use pressureInletVelocity for inlet and zeroGradient for outlet.
sorry for bad English
parthigcar likes this.
Second order scheme with buoyantSimpleFoam mighelone OpenFOAM Running, Solving & CFD 2 September 26, 2012 11:28
BuoyantSimpleFoam amitshah OpenFOAM Running, Solving & CFD 4 June 3, 2009 07:04
BuoyantSimpleFoam massFlowRate hellorishi OpenFOAM Running, Solving & CFD 0 March 13, 2009 06:57
BuoyantSimpleFoam solver crashes prashant24983 OpenFOAM Running, Solving & CFD 6 October 28, 2008 07:03
Instability in buoyantSimpleFoam smehdi609 OpenFOAM Running, Solving & CFD 1 August 20, 2008 16:38
