When to set momentumPredictor to Yes
Like Tree21Likes
  • 1 Post By hsieh
  • 7 Post By pierre
  • 2 Post By eugene
  • 8 Post By hjasak
  • 3 Post By matejfor
Old   March 14, 2006, 23:58
Default Hi, Can someone tell me und
Pei-Ying Hsieh
hsieh is on a distinguished road
Can someone tell me under what condiction should momentumPredictor be set to yes? Thanks!
Pei
vivek05 likes this.
hsieh is offline   Reply With Quote
Old   March 15, 2006, 06:35
Default As far as I understand, in the
Pierre Le Fur
pierre is on a distinguished road
As far as I understand, in the pressure-velocity algorithm for two-phase flows in Foam does not need the momentum equation to be solved, so in general momentumPredictor should be set to no, especially for "challenging" test cases (i.e if there is problems with convergence or sharp volume fractio gradient). In this case the momentum equation is only constructed and used to obtain fluxes and solve the pressure equation. On the other hand solving the momentum eqaution might speed up convergence in non-challenging steady-state calculations.
Hope that helps
Pierre
pierre is offline   Reply With Quote
Old   March 15, 2006, 15:54
Default Thanks Pierre! How about tu
Pei-Ying Hsieh
Thanks Pierre!
How about turbFoam?
Pei
Old   March 16, 2006, 15:07
Default TurbFoam uses the standard PIS
Pierre Le Fur
TurbFoam uses the standard PISO algorithm, momentum equation is always solved. it can be used for unsteady or steady cases.
Pierre,
Old   January 22, 2009, 06:53
Default Hi together, for me it is n
Marc Wattenberg
marc_wattenberg is on a distinguished road
Hi together,
for me it is not clear where the velocity field is coming from when the momentum equation is not solved. perhaps it is a stupid question but for the moment a need a hint
thanks
marc
marc_wattenberg is offline   Reply With Quote
Old   January 22, 2009, 07:32
Default U = U* - grad(p)/A where U*
Eugene de Villiers
eugene is on a distinguished road
U = U* - grad(p)/A
where U* = H/A
i.e. U is solved explicitly after the pressure equation.
minh khang and Zane like this.
eugene is offline   Reply With Quote
Old   January 22, 2009, 12:25
Default Hi Marc, It depends on the
Hrvoje Jasak
Hi Marc,
It depends on the importance of the laplacian in the momentum equation: if you have important diffusivity in the momentum, you should solve the momentum equation implicitly.
Enjoy,
Hrv
minh khang, ancolli, Swift and 5 others like this.
Hrvoje Jasak
Old   March 16, 2010, 05:16
Claus Meister
idrama is on a distinguished road
Hey Foamers,
I read your posts. Could anybody tell me where to find a direct statement about this, i.e. no long text. Friends referred me to Ferziger. But I cannot find the right page.
Cheers
idrama is offline   Reply With Quote
Old   March 16, 2010, 08:27
Sandy Lee
sandy is on a distinguished road
I want to know too. I guess, if we set no, maybe it is slow to get convergence to some cases, but they will get the same results, right? Who can give some light?
sandy is offline   Reply With Quote
Old   March 17, 2010, 03:10
matej forman
matejfor is on a distinguished road
Dear Claus,
Ferzinger , Peric, Comput. Methods for Fluid Dynamics is very good book and I guess you should read it all anyway. But not to waste your time, have a look at chapter 7.5 as a start. Also these slides from stanford I googled my appeal:http://www.stanford.edu/class/me469b...mpressible.pdf
As a good quote from this site sais: "Two weeks of playing with a CFD code will save you one afternoon of reading". (sorry, I forgot the author).
good luck
matej
Nicole, CFDTeufel and shizuka like this.
matejfor is offline   Reply With Quote
