November 24, 2008, 21:54 |
Hi former:
I used version
liu yang
Rep Power: 17 |
Hi former:
I used version 1.5 for flow around oscillating cylinder,but it seems that two files: cellMotionU and pointMotionU. I used a file pointMotionU like this: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { cylinder { type oscillatingVelocity; omega 0.1; amplitude (0 -0.628318531 0); value uniform (0 0 0); } up { type fixedValue; value uniform (0 0 0); } down { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } frontAndBackPlanes { type empty; } } and the same for cellMotionU. There seems to be something wrong, the error message is: gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type oscillatingVelocity) on patch cylinder of field cellMotionU in file "/home/ly/OpenFOAM/ly-1.5/run/os_cyclinder/0/cellMotionU" You are probably trying to solve for a field with a generic boundary condition. Then what should the file cellMotionU should look like? Thanks a lot. |
November 25, 2008, 00:21 |
I think removing the ce
Mathieu Olivier
Rep Power: 17 |
I think removing the cellMotionU file from the "0" directory will solve the problem. Mathieu |
November 25, 2008, 02:22 |
Hi:
Following your instruct
liu yang
Rep Power: 17 |
Hi:
Following your instruction,it works now.Thank you very much. LiuYang |
February 24, 2009, 05:16 |
for an oscillating s
patrick riemer
Rep Power: 17 |
for an oscillating sine motion with vel_amp_x=0.226m/s and frequency of 128Hz i used oscillatingVelocity and a pointMotionU with type oscillatingVelocity; omega 804.096; //=2*pi*f amplitude (0.226 0 0); value uniform (0 0 0); But the oscillating amplitude seems to be much too high. what do i do wrong? The oscill....C file under fvMotionSolver/pointPatchFields/derived/oscillatingVelocity is standard with (p0_ + amplitude_*sin(omega_*t.value()) - p.localPoints()) /t.deltaT().value() ); Thank you for a hint |
February 24, 2009, 11:16 |
Patrick,
You need oscillati
Sopheak Seng
Rep Power: 17 |
Patrick,
You need oscillatingDisplacement and not oscillatingVelocity. Are you using OF 1.5? Have you had any problem with oscillatingFixedValue? Sopheak |
February 24, 2009, 14:16 |
I donīt think that i
patrick riemer
Rep Power: 17 |
I donīt think that i MUST use oscillatingDisplacemt. I can also describe the motion by oscillatiingVelocity, with the maximum value of velocity as the amplitude, and omega as 2*pi*f. I want to use it for pointMotionU, the inputfile for velocitylaplacian (dynamic mesh). The oscillatingFixedValue b.c. is not supported here, so i need oscillatingVelocity. COuld you tell me the correct entries and meanings for omega and value uniform? By the way, what is p0? |
February 25, 2009, 08:36 |
canīt anybody help me? tried i
patrick riemer
Rep Power: 17 |
canīt anybody help me? tried it again today, but the meshmotions isnīt the expected. the amplitude is much too high!
February 25, 2009, 09:01 |
Patrick,
Try to use oscilla
Sopheak Seng
Rep Power: 17 |
Patrick,
Try to use oscillatingDisplacemt on the velocity field and you will be suprise. Just change oscillatingVelocity to oscillatingDisplacemt. Sopheak |
February 25, 2009, 09:12 |
like this:
type oscillating
#9 |
Sopheak Seng
Rep Power: 17 |
like this:
type oscillatingDisplacement; omega 804.096; //=2*pi*f amplitude (0.226 0 0); value uniform (0 0 0); |
February 25, 2009, 10:21 |
Thank you very much, i am one
#10 |
patrick riemer
Rep Power: 17 |
Thank you very much, i am one step further right now!
I could change the sin to a cos-motion by editing the oscillatingDisplacement...C file. And it still works. Patrick |
February 25, 2009, 10:43 |
I have to mention that there w
#11 |
patrick riemer
Rep Power: 17 |
I have to mention that there were of course changes in the dynamicmeshdict (to displacementlaplacian)
fvsolution and fvschemes necessary. and the file in 0 should be called pointDisplacement. |
July 7, 2013, 02:49 |
which changes should we do for (fvsolution and fvschemes)?!?
#12 |
Pedram Pakad
Rep Power: 13 |
which changes should have for
(fvsolution and fvschemes)?!? please help me!! |
July 25, 2013, 17:02 |
#13 |
Gecamp
Rep Power: 15 |
Prolly he refers to the fact that you have to specify a solver for 'cellDisplacement' in fvSolution and a scheme for the diffusivity under 'laplacianSchemes' in fvSchemes.
I personally use 'PCG' for the first and 'Gauss linear corrected' for the second. Bye |
July 26, 2013, 06:49 |
#14 | |
Pedram Pakad
Rep Power: 13 |
thanx for your hint. i have another question??!! what is your idea about dynamicMeshDict for angular Oscillating displacement. which method, solver and diffusivity should i use?!? |
July 26, 2013, 09:18 |
#15 |
Gecamp
Rep Power: 15 |
Hi Pedram!
Well, I'm quite new regarding dynamic mesh movement. Here below you can find my setting which has worked so far but more runs need to go before I can develop a critical point of on it dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solver displacementLaplacian; diffusivity inverseDistance (solidGeometryName); Now I've got a question for you, do you know how to run with OF the only mesh movement without solving the NS equations? I just need to check the motion quickly and I dont want to solve the whole flow fields. |
July 26, 2013, 10:05 |
#16 |
Pedram Pakad
Rep Power: 13 |
Hi desmoge.
I have done the this and unfortunately in large amplitude it got an error!!! And about your question... You can solve your problem and after that, you can see the mesh changes in paraView. In paraView you can set solid color and change surface to surface with edges. Now you can run paraview and see the mesh motion. |
August 20, 2013, 02:22 |
oscillate problem
#17 |
Pedram Pakad
Rep Power: 13 |
Hi everyone. I want to analyze heat transfer of oscillating cylinder.
When I use inversedistance as diffusivity I didn't get a correct answer for nusselt number. It is same as the fixed cylinder. What should I do?!? |
November 3, 2013, 14:55 |
#18 | |
mohammadreza sattari
Rep Power: 12 |
In order to only deform the mesh without doing any flow calculations the "moveMesh" utility can be used. |
problem with oscillating cylinder | ammi | FLUENT | 0 | December 18, 2006 04:06 |
Oscillating cylinder | MC | Main CFD Forum | 5 | September 6, 2006 21:41 |
UDF for oscillating cylinder | fredD | FLUENT | 0 | July 16, 2004 09:32 |
flow around oscillating cylinder | gs | Main CFD Forum | 0 | May 31, 2004 06:34 |
need help,rotatary oscillating cylinder | Filly | FLUENT | 3 | October 4, 2000 09:11 |
