October 31, 2024, 08:45 |
interIsoFoam
Elias Michelsen Tangen
Rep Power: 2 |
Hello!
I have openFoam version 11 and want to use the interIsoFoam for my simulation. But i cant find it. Do i need another version of OF or do i have to add something in my fvSolution. I noticed for instance that my openfoam version does not explicitly have sonicFoam installed, but it turned out it was incorporated with the rhoPimpleFoam and that i just had to add transonic yes; inside PIMPLE in my fvSolution to use it. Thanks! |
October 31, 2024, 09:01 |
Yann
Rep Power: 29 |
Hello Elias,
AFAIK, this solver is only implemented in the OpenCFD branch (openfoam.com). Regards, Yann |
October 31, 2024, 10:42 |
Rep Power: 2 |
Does the .com version come with more solver options in general? Whats the benefit of using .com VS .org
October 31, 2024, 11:08 |
Yann
Rep Power: 29 |
This is a big topic and there is no simple answer.
Both branches have the same origin but evolved differently for years now. There are common features between both branches, and features/solvers which are specific to each branch. You should probably pick a branch according to what you need to do with OpenFOAM. Depending on your applications and the solvers/features you need, one branch could be a better fit than the other. If you are new to OpenFOAM, I would have few recommendations:
interisofoam |
Selecting curvature estimation RDF-model in interIsoFoam solver | Swirl | OpenFOAM Running, Solving & CFD | 0 | May 23, 2023 13:49 |
interIsoFoam extremely slow | 5tern | OpenFOAM Running, Solving & CFD | 0 | June 9, 2022 05:03 |
Modeling free-surface river connection with interIsoFoam | GrivalszkiP | OpenFOAM Running, Solving & CFD | 0 | November 17, 2020 12:14 |
from interFoam to interIsoFoam | brammekeuh987 | OpenFOAM Running, Solving & CFD | 2 | April 18, 2020 08:52 |
[isoAdvector] interIsoFoam - which OpenFOAM versions are supported? | kk415 | OpenFOAM Community Contributions | 1 | November 29, 2018 07:51 |
