Introducing the combined Poisson-Boltzmann-Ohmic Library for rheoTool in OpenFOAM
Like Tree1Likes
  • 1 Post By saicharan662000@gmail.com
Old   August 13, 2024, 13:53
Smile Introducing the combined Poisson-Boltzmann-Ohmic Library for rheoTool in OpenFOAM
hari charan
saicharan662000@gmail.com is on a distinguished road
Hello OpenFOAM Community,
I am excited to share that I have developed a new library called myOhmic as part of the OpenFOAM suite. This library is designed to simulate and analyze fluid flow involving electrokinetic effects using both the Ohmic model and the Poisson-Boltzmann-Ohmic (PBO) model.
The myOhmic library integrates with OpenFOAM and allows for the computation of forces and electroosmotic flow in complex geometries, such as T-channels. The PBO model, in particular, provides a more accurate representation of the near-wall effects and shear thinning behavior, leading to improved stability and higher accuracy in certain flow regimes. I did this because the slip velocity model is over predicting the instability when a shear thinning fluid is used. So solving PB equation near the wall and transport equations in bulk fluid makes a good prediction of electro kinetic instability.
You can find the code and documentation on my GitHub repository here: https://github.com/hcharan61/Enhance...nFoam-rheotool
I look forward to any feedback and hope this library will be of use to others working on similar simulations.
Best regards,
nikoscham likes this.
saicharan662000@gmail.com is offline   Reply With Quote
carreau, openfoam9, power law fluid, rheotool, shear thinning
Duplicate library entries when running a solver with custom library francescomarra OpenFOAM Programming & Development 3 May 17, 2022 09:37
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 14:15
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
Poisson equation combined with transport equation Se-Hee CFX 0 December 27, 2007 02:00
