July 23, 2024, 17:45 |
I have used OF gui but not OF CLI
Matt
Rep Power: 2 |
Ok, so i have some questions and i am hoping to get some help. I am going to need a lot of help haha.
For the last few months i have been using a GUI for openfoam which has made simulations very nice and simple to run. This GUI is the cfdOF workbench in Ondsel engineering suit (fork of freecad) and its been a blessing to say the least. all i have to do is double click something like PHYSICS and then pick my settings such as steady time or transient time, single phase, multiphase flow, isothermal, high Mach number viscous, etc etc. Then i move to fluid properties, initialize fields etc etc. I then can do mesh, mesh refinement based on extrusion, surface or volume, and then i can add a reporting function for forces and force coefficients. i mean, its very very nice. However, i kind of want to try OF from the command line interface or however it is normally run without a gui. So here is my question. i have made a simple ogive projectile, a nose cone for a rocket of mine, as i build high powered rockets. IE, my prefect of my team, his rocket hit 300,000 feet. so, i have this step file of a 3d nose cone i made, and now i would like to CFD the projectile. when i did this with the GUI, i had the following: a flow domain 10 times the size in all directions. A surrounded my nose cone with a 3d cube 10 times the size of the cone 4 volume mesh refinements. I did this by placing 4 cylinders centered around the nose cone, each cylinder twice the size of the other. Flow had a course mesh, then each cylinder was set to be a specific refinement so that the mesh on the nosecone was about 10mm for each cell. the flow domain was set to open farfield with 750m/s in the x direction RANS k-omega-sst default 1.25kg/m3 HiSA solver was used. got back results that matched openrockets numerical analysis. So i would like to learn to do the same thing without the GUI I have a 12 core cpu machine and 32gb of gddr4 ram. It handled the 3d case just fine. took about 10 minutes or less for 2000 iterations Being honest and upfront, im going to need hand holding on this. thanks to anyone willing |
July 24, 2024, 07:04 |
Rep Power: 14 |
Your best bet is to book onto a training course - there you will be led through the process and gain proficiency rapidly. Otherwise, google for training course notes (eg Wolf dyamics) and try work through them yourself, using the tutorial cases as a starting point. I doubt that you will find someone with the time or goodwill to act as a personal tutor ...
July 24, 2024, 19:12 |
#3 | |
Matt
Rep Power: 2 |
thanks |
July 24, 2024, 19:36 |
Matt
Rep Power: 2 |
before i move on, i found that openfoam themselves have some training. I found the pdf of the tutorials in my OF install folder BUT for whatever reason, i do not have the tutorials folder that is supposed to be downloaded. How do i find those files and folders?
i am on windows 10. Is this why they are not available? |
July 25, 2024, 03:52 |
Rep Power: 14 |
Not sure - I used OF under WSL many years ago, and I don't remember them being missing. But they may well be in your source pack.
Simple remedy: go to the OpenFOAM page (org or ESI) and download the linux source file pack that matches your OpenFOAM version - you will find the tutorials in there. You can discard the rest, of course. |
July 25, 2024, 03:54 |
Rep Power: 14 |
On the subject of training, a quick google in YT found the following playlist:
https://www.youtube.com/watch?v=uNpM...mDChejiwm846Wl I haven't watched these, but I do know that the Wolf Dynamics guys generate some really good training course material, some of which is freely available on the web. Good luck. |
July 25, 2024, 20:52 |
#7 | |
Matt
Rep Power: 2 |
July 25, 2024, 21:15 |
#8 | |
Matt
Rep Power: 2 |
July 26, 2024, 05:45 |
#9 |
Rep Power: 14 |
No problem - and good luck!
TEXT USER INTERFACE command from GUI PANEL/ACTION or TUI command from GUI command | DAMI46 | FLUENT | 0 | July 3, 2024 08:53 |
SnappyHexMesh GUI add-on for Blender | tkeskita | OpenFOAM Pre-Processing | 22 | April 22, 2024 11:45 |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
CFD Codes and GUI | ganuganu | Main CFD Forum | 6 | July 22, 2019 06:50 |
Command Line vs. GUI Menus | Go | FLUENT | 0 | June 8, 2005 16:05 |
