Continuity error cannot be removed by adjusting the outflow. |
June 18, 2024, 05:51 |
Israel
Rep Power: 2 |
How do I deal with this error? I can't get my hands on where the error is from. I have looked at the boundary conditions multiple times. This is a pressure-driven flow where the inlet and outlet pressure conditions are known. However, the velocities are not.
June 18, 2024, 05:52 |
Israel
Rep Power: 2 |
Here are my boundary conditions.
June 18, 2024, 06:14 |
Yann
Rep Power: 27 |
When using solvers using p_rgh, you need to define your pressure BC on p_rgh and define p BCs as calculated. Try and see if it solves your issue. Yann |
June 19, 2024, 04:57 |
Israel
Rep Power: 2 |
Thanks. This helped!
Continuity error cannot be removed by adjusting the outflow | Mondal131211 | OpenFOAM | 7 | September 27, 2018 01:49 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Continuity error cannot be removed by adjusting the outflow - rotating domain case | Swift | OpenFOAM Running, Solving & CFD | 4 | July 10, 2017 08:36 |
Continuity error cannot be removed by adjusting the outflow. Please check the velocit | range_rover | OpenFOAM Running, Solving & CFD | 7 | August 17, 2016 01:12 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
