May 30, 2024, 14:53 |
2D airfoil simulations overpredicting drag
Katherine
Rep Power: 10 |
I'm interested in simulating simple 2-D flow over a NACA0012 airfoil, starting with an AoA of 12 degrees. I'm using the k-omega SST turbulence model for closure, with the freestream velocity at 100 m/s, corresponding to a Re # of ~6.6 million. I've used a separate script to setup the mesh with OpenFOAM's blockMesh capabilities, and have been working on refining the mesh to a sufficient point without being too computationally intensive. However, throughout this effort, I have consistently been over-predicting the drag by several orders of magnitude. Comparing with a similar Re # from inviscid results obtained from XFLR5, Cd should be around 0.013, but I am getting around 0.17, an order-of-magnitude of 10 higher. The lift coefficient is a bit better, at 1.09 (XFLR5 is around 1.3). Without comparing to other results I know the drag is wrong. I've included the controlDict file here: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application rhoPimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 5; deltaT 2e-5; writeControl adjustableRunTime; //div(phi,U) bounded Gauss linear; //div(div(phi,U)) Gauss linear; writeInterval 0.005; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 1.5; functions { #includeFunc residuals #includeFunc forces #includeFunc forceCoefficients } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.01; } pFinal { $p; relTol 0; } "(rho|U|k|omega|e)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0.1; } "(rho|U|k|omega|e)Final" { $U; relTol 0; } } SIMPLE { residualControl { p 1e-4; U 1e-4; "(k|omega|e)" 1e-4; } nNonOrthogonalCorrectors 0; } PIMPLE { nCorrectors 2; nNonOrthogonalCorrectors 0; nOuterCorrectors 10; } relaxationFactors { equations { ".*" 0.3; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; limited cellLimited Gauss linear 1; grad(U) $limited; grad(k) $limited; grad(omega) $limited; } divSchemes { default none; div(phi,U) Gauss linearUpwind limited; turbulence Gauss linearUpwind limited; energy Gauss linearUpwind limited; div(phi,k) $turbulence; div(phi,omega) $turbulence; div(phi,e) $energy; div(phi,K) $energy; div(phi,Ekp) $energy; div(phi,(p|rho)) $energy; div((phi|interpolate(rho)),p) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } // ************************************************************************* // |
May 31, 2024, 06:30 |
Yann
Rep Power: 27 |
How is defined your forceCoeffs function? Couldn't it be an issue with the reference frame used to compute the coefficients? (liftDir and dragDir?) Yann |
June 1, 2024, 01:31 |
Katherine
Rep Power: 10 |
It could be, I can definitely look into that. Here is the forceCoefficients and forces definitions:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object Force; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // forceCoefficients { type forceCoeffs; functionObjectLibs ("libforces.so"); writeControl timeStep; writeInterval 1; patches ("surfaces"); writeFields no; log true; patches ("surface"); pName p; UName U; dragDir (1 0 0); liftDir (0 1 0); pitchAxis (0 0 1); CofR (-0.75 0 0); magUInf 100; // free stream velocity; inlet condition!! lRef 1; Aref 1; //0.79; // cross sectional area; should be this instead of 1 rhoName rhoInf; // of-v301 rho rhoInf; // of-v1706 rhoInf 1.205; origin (0 0 0); coordinateRotation { type EulerRotation degrees true; rotation (0 0 0); } binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object Force; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // forces { type forces; functionObjectLibs ("libforces.so"); writetControl timeStep; writeInterval 1; patches ("surface"); pName p; UName U; rhoName rhoInf; // of-v301 rho rhoInf; // of-v1706 rhoInf 1.205; log true; CofR (-0.75 0 0); // origin for moment calculation writeFields no; binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } // ************************************************************************* // |
June 1, 2024, 04:45 |
Yann
Rep Power: 27 |
How is your reference frame defined?
Is it aligned with the inlet flow and you're moving the airfoil to simulate different aoa, or is it aligned with the airfoil and you're changing the inlet flow to change aoa? To get proper force coefficients your dragDir and liftDir parameters have to be defined according to the inlet flow direction. |
June 17, 2024, 13:01 |
Katherine
Rep Power: 10 |
Thanks for your comment - that makes sense. I'm changing the inlet flow to change the angle of attack, and so the reference frame is coded now to be aligned with the airfoil. I can try changing dragDir and liftDir to be aligned with the inlet velocity then and see if this makes a difference. By chance, have you tried this? Thanks!
June 18, 2024, 03:51 |
Yann
Rep Power: 27 |
June 28, 2024, 15:51 |
Katherine
Rep Power: 10 |
Thanks for your message - yes, that's correct, and I did update things to compute the forces in the body-reference frame for the airfoil. Lift is still reasonable but unfortunately drag is still high. I am curious if anyone else ran into this issue. Thanks!
June 30, 2024, 05:23 |
Yann
Rep Power: 27 |
As far as I know on airfoils it is usually harder to get a good agreement on drag than it is on lift. But of course it depends on how far you are from your reference values. By the way, have you checked this? https://doc.openfoam.com/2312/exampl...lent/naca0012/ |
June 30, 2024, 05:36 |
Negative lift coefficient
#9 |
Puttanna
Hello
I'm doing simulation for co flow jet airfoil in which lift coefficient is negative.. can someone help me please!! |
airfoil 2d, overpredicting, unsteady compressible |
Calculation of Drag Coefficient for Airfoil | fredi | Main CFD Forum | 3 | September 28, 2021 07:57 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
Drag on an Airfoil | Easyqus | FLUENT | 0 | January 31, 2016 17:17 |
Drag prediction for Naca 23012 airfoil | Ravel Bogatec | CFX | 17 | February 15, 2008 00:21 |
Airfoil Drag Force | wowakai | Main CFD Forum | 3 | October 13, 1998 19:27 |
