April 30, 2024, 09:40 |
Input file for foammooring
Haris Hameed
Rep Power: 17 |
I am using foammooring coupled with OpenFAOM to simulate the OC5 floater. the mooring data is given in literature which also specifies Equivalent mooring line extensional stiffness as 753.6 × 10^6 N/m. But i am not sure where to put the stiffness value in the inputfile. There is EA in Newton and bottom stiffness (pa/m). but i am not sure if this value goes here. can anyone guide me on this. This is the link for the reference paper that has these properties. [Paper Link] |
June 12, 2024, 10:00 |
PengBin
hello Haris Hameed,
you can check the official introduction here:https://moordyn.readthedocs.io/en/la...nputs.html#id2 which says EA is the line stiffness, product of elasticity modulus and cross-sectional area (N). BTW, could you tell me what's the vaule of your dtM? i set the dtM as the official instruction(same with the openfoam case delta T), but it comes out with error. |
foammooring, moordyn, openfoam, properties, stiffness |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
