p_rgh causes problems
Like Tree1Likes
  • 1 Post By Lorddrinkalot
Old   April 28, 2024, 08:50
Default p_rgh causes problems
Christoph Trier
Lorddrinkalot is on a distinguished road
Hey guys,
I have a problem with my simulation, and I don't know any further.
At the moment, I'm just trying to simulate a normal flow through an L-shaped geometry (image attached). For now, it's isothermal and with a B field of 0.
The boundary condition for U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.02 0 0);
    outlet
		type    zeroGradient;
        //type          pressureInletOutletVelocity;
		//value			uniform (0 0 0);
    Wall_side
        type            noSlip;
    Wall_out
        type            noSlip;
    Wall_inside
        type            noSlip;
Conditions for the p_rgh
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedFluxPressure;
		value			uniform 0;
    outlet
	    type            fixedValue;
        value           uniform 0;
	    //type            fixedFluxPressure;
		//value			uniform 0;
        //type            inletOutlet;  //outletInlet
		//inletValue		uniform 0;
    Wall_side
		value			uniform 0;
    Wall_out
		value			uniform 0;
    Wall_inside
		value			uniform 0;
I have tried several conditions with inlet/outlet, etc., but nothing helps.
For the first few time steps, everything seems good, but then after some time, the pressure flips or does something strange (see images). The inlet is at the bottom, and the outlet is on top of it. So, the flow comes in at the bottom half of the L and leaves at the top half.
I am new to OpenFOAM, and I can't figure out why this is happening.
I'm using the buoyantPimpleMhdFoam (MHD and heat transfer), but both are switched off for now to check and see if the case is running, which it is not.
Boundary condition: no heat transfer, so it's constant.
internalField   uniform 573;
boundaryField
    inlet
        type            fixedValue;
		value			uniform 573;
    outlet
        type    zeroGradient;
    Wall_side
        type    zeroGradient;
    Wall_out
        type    zeroGradient;
    Wall_inside
        type    zeroGradient;
The B field is set to 0 in the conditions (internalField uniform (0 0 0).
Please let me know if you need anything else.
Can someone help me with this kind of problem??
Thanks, Christoph
Lorddrinkalot is offline   Reply With Quote
Old   April 28, 2024, 11:57
Default Addition
Christoph Trier
Hey,
I added a GitHub repository for the case to see the different files.
https://github.com/Lorddrinkalot/OpenFoam_Case.git
I should mention that I am using the Boussinesq approximation.
I also tried it with icoPolynomial, and in that case, the solver is working. However, for my case, I need the Boussinesq equation of state, and in that case, some weird stuff is happening.
Old   May 2, 2024, 05:57
Roman
Roman1 is on a distinguished road
With the other solvers (ex. fireFoam) p_rgh must be approximately the same as normal pressure, not zero. This is a common pressure corrected with the height.
Roman1 is offline   Reply With Quote
Old   May 2, 2024, 19:14
Will Kernkamp
wkernkamp is on a distinguished road
Yes, and isn't that a compressible solver (to model buoyancy).
wkernkamp is offline   Reply With Quote
Old   May 13, 2024, 15:06
Christoph Trier
So, hey guys,
I fixed my problems, or rather, I let it run longer. My problem was that I didn't let the Simulation run long enough in the business approximation. After simulation for some hours, the Pressure P-rough looks rigth
wkernkamp likes this.
p_rgh, p_rgh devergence
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
