VoF method with heat transfer and phase change |
April 24, 2024, 02:55 |
Almanzo Arjuna
Rep Power: 4 |
Hi, I want to simulate a water heat pipe, specifically I want to see the phase change between liquid and vapor in the evaporator region of a heat pipe.
Currently I'm using openfoam v11, If I want to use VoF method with heating, what solver should I use? I'm still looking into incompressibleMultiPhaseVoF tutorial files, but I can't seem to find a case that relevant to my case. Any suggestions? |
April 24, 2024, 13:16 |
Shravan
Rep Power: 9 |
You can take a look at the interCondensatingEvaporatingFoam in the ESI version of OpenFOAM. https://www.openfoam.com/documentati...ngFoam_8C.html https://www.tfd.chalmers.se/~hani/ku...Yaquan_Sun.pdf Check out the tutorial as well: https://develop.openfoam.com/Develop...vaporatingFoam Thanks |
heat transfer, multi phase flow, vof |
Is there a VOF (CST) foam code for phase change into the air media? | Asghari_M | OpenFOAM Programming & Development | 4 | February 17, 2021 11:41 |
Conjugate heat transfer with phase change produced wrong temperature | qtruong | OpenFOAM Programming & Development | 0 | July 10, 2018 15:16 |
conjugate heat transfer with phase change | mogoko | CFX | 2 | March 23, 2011 12:25 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 02:49 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 24, 2001 00:16 |
