April 22, 2024, 11:55 |
cannot blockMesh, ./Allrun and ./AllClean
Rep Power: 2 |
Hello, I have problem to do simulation for twoPhasePachuka, could anyone have solution for my problem?
:~/FirstTime/MPPICInterFoam/twoPhasePachuka$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _fbf00d6b-20230626 OPENFOAM=2306 version=2306 Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : Apr 22 2024 Time : 23:45:40 Host : DESKTOP-GM7974Q PID : 670 I/O : uncollated Case : /home/shukrie/FirstTime/MPPICInterFoam/twoPhasePachuka nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: (openfoam-2306) "/home/shukrie/FirstTime/MPPICInterFoam/twoPhasePachuka/system/blockMeshDict" From int main(int, char**) in file findBlockMeshDict.H at line 81. FOAM exiting ~/FirstTime/MPPICInterFoam/twoPhasePachuka$ ./Allrun -bash: ./Allrun: Permission denied :~/FirstTime/MPPICInterFoam/twoPhasePachuka$ ./Allclean -bash: ./Allclean: Permission denied |
April 22, 2024, 13:00 |
Rep Power: 14 |
The "permission denied" messages indicate that you do not have the permission to execute the Allrun or Allclean scripts. This is most likely because you don't own the file.
Do a "ls -l" command in the directory and you will see who owns the file and what the permissions are on the file. Ideally you should own the file and you should have something like "-rwxr--r--", which means that the owner can execute, but group and others cannot (they can just read). If you have no idea what I am talking about, then google the linux chown command and read up on file permissions. The fix depends on: what the file permission state is and who owns it, and what privilidges you have on the machine, but hopefully the above is enough to get you started on the right road. |
April 23, 2024, 05:41 |
Rep Power: 2 |
Thank you so much for the enhancement. It really helps me in my final year project.
CentFOAM & openfoam2.2.x (troubles with runApplication ...) | paul18 | OpenFOAM Installation | 16 | August 6, 2013 09:39 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
