March 4, 2024, 06:04 |
parallel simulation problem
I´m simulating with parrallel InterFoam and I have this problem. In the case I can do the decomposePar and the setfields without problem, but when I execute the interFoam comand I have this problem. The command that I use is: mpirun -np 4 interFoam -parallel > log.interFoam & --> FOAM FATAL ERROR: bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor --> FOAM FATAL ERROR: From function static bool Foam::UPstream::init(int&, char**&, bool) in file UPstream.C at line 112. FOAM aborting bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor From function static bool Foam::UPstream::init(int&, char**&, bool) in file UPstream.C at line 112. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&) --> FOAM FATAL ERROR: bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor From function static bool Foam::UPstream::init(int&, char**&, bool) in file UPstream.C at line 112. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) --> FOAM FATAL ERROR: bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor From function static bool Foam::UPstream::init(int&, char**&, bool) in file UPstream.C at line 112. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? at ??:? #1 Foam::error::abort()#1 Foam::error::abort() at ??:? #1 Foam::error::abort() at ??:? #1 Foam::error::abort() at ??:? #2 Foam::UPstream::init(int&, char**&, bool) at ??:? #2 Foam::UPstream::init(int&, char**&, bool) at ??:? #2 Foam::UPstream::init(int&, char**&, bool) at ??:? #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:? #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:? #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:? #2 Foam::UPstream::init(int&, char**&, bool) at ??:? #3 Foam::argList::argList(int&, char**&, bool, bool, bool) at ??:? #4 at ??:? #4 at ??:? #4 ??? at ??:? #4 in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFo in "/oam" pt/openfoam9/platforms/#5 ?linux64GccDPInt32Opt/bin/interFoam" #5 ?? in "/lib/x86_64-linux-gnu/libc.so.6" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc in "/lib/x.so.6" 86_64-linux-gnu/libc.#6 __libc_start_mainso.6" #6 __libc_start_main in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" #5 ? in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/lib/x86_64-linux-gnu/libc.so.6" ?#6 __libc_start_main?? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" [cmt536:1048508] *** Process received signal *** [cmt536:1048508] Signal: Aborted (6) [cmt536:1048508] Signal code: (-6) [cmt536:1048508] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fca9f042520] [cmt536:1048508] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fca9f0969fc] [cmt536:1048508] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fca9f042476] [cmt536:1048508] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fca9f0287f3] [cmt536:1048508] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x20d)[0x7fca9fab843d] [cmt536:1048508] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3e9 )[0x7fcaa2c70d19] [cmt536:1048508] [ 6] in "/lib/x86_64-linux-gnu/libc.so.6" #7 /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x7a8)[0x7fca9fad3bf8] [cmt536:1048508] [ 7] interFoam(+0x45d5a)[0x555b6eda1d5a] [cmt536:1048508] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fca9f029d90] [cmt536:1048508] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fca9f029e40] [cmt536:1048508] [10] interFoam(+0x55b25)[0x555b6edb1b25] [cmt536:1048508] *** End of error message *** in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" [cmt536:1048509] *** Process received signal *** [cmt536:1048509] Signal: Aborted (6) [cmt536:1048509] Signal code: (-6) [cmt536:1048509] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fdb55a42520] [cmt536:1048509] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fdb55a969fc] [cmt536:1048509] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fdb55a42476] [cmt536:1048509] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fdb55a287f3] [cmt536:1048509] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x20d)[0x7fdb564b843d] [cmt536:1048509] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3e9 )[0x7fdb596a5d19] [cmt536:1048509] [ 6] in "/opt/openfoam9/opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x7a8)[0x7fdb564d3bf8] [cmt536:1048509] [ 7] /platforms/liinterFoam(+0x45d5a)[0x55d5dee23d5a] [cmt536:1048509] [ 8] nux64GccDPInt32Opt/b/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fdb55a29d90] [cmt536:1048509] [ 9] in/interFoam" /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fdb55a29e40] [cmt536:1048509] [10] interFoam(+0x55b25)[0x55d5dee33b25] [cmt536:1048506] *** Process received signal *** [cmt536:1048506] Signal: Aborted (6) [cmt536:1048506] Signal code: (-6) [cmt536:1048509] *** End of error message *** [cmt536:1048506] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fb33b842520] [cmt536:1048506] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fb33b8969fc] [cmt536:1048506] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fb33b842476] [cmt536:1048506] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fb33b8287f3] [cmt536:1048506] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x20d)[0x7fb33c2b843d] [cmt536:1048506] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3e9 )[0x7fb33f471d19] [cmt536:1048506] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x7a8)[0x7fb33c2d3bf8] [cmt536:1048506] [ 7] interFoam(+0x45d5a)[0x556f6b236d5a] [cmt536:1048506] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fb33b829d90] [cmt536:1048506] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fb33b829e40] [cmt536:1048506] [10] interFoam(+0x55b25)[0x556f6b246b25] [cmt536:1048506] *** End of error message *** ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/interFoam" [cmt536:1048507] *** Process received signal *** [cmt536:1048507] Signal: Aborted (6) [cmt536:1048507] Signal code: (-6) [cmt536:1048507] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f4f6a442520] [cmt536:1048507] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f4f6a4969fc] [cmt536:1048507] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f4f6a442476] [cmt536:1048507] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f4f6a4287f3] [cmt536:1048507] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x20d)[0x7f4f6aeb843d] [cmt536:1048507] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x3e9 )[0x7f4f6d95ed19] [cmt536:1048507] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x7a8)[0x7f4f6aed3bf8] [cmt536:1048507] [ 7] interFoam(+0x45d5a)[0x55b187774d5a] [cmt536:1048507] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f4f6a429d90] [cmt536:1048507] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f4f6a429e40] [cmt536:1048507] [10] interFoam(+0x55b25)[0x55b187784b25] [cmt536:1048507] *** End of error message *** ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 1048506 RUNNING AT cmt536 = EXIT CODE: 9 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ================================================== ================================= YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions |
March 4, 2024, 06:35 |
same error as soon as i switched to v2312
chandrashekhar a patankar
Rep Power: 3 |
Run Mode:Platform MPI Local Parallel core problem | mztcu | CFX | 0 | October 13, 2016 03:14 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
A parallel simulation problem in DPM | satum | FLUENT | 0 | October 21, 2008 05:38 |
