February 19, 2024, 03:14 |
Anisotropic Material
Ragav
Rep Power: 2 |
Hi all,
I am trying to do a heat transfer between 2 different solids. One of which has anisotropic behavior. I have read a few threads -directionalKSolidThermo syntax. I believe we can add the thermal conductivities of the Anisotropic material in different directions to the thermophysical properties file of that material. Please advise a direction to begin with. Any leads would be much appreciated. Thanks. |
February 19, 2024, 04:11 |
#2 | |
Yann
Rep Power: 27 |
There might be different options depending on the OpenFOAM development branch. From what I remember: In the OpenCFD branch (openfoam.com) since OpenFOAM-v2206: New tabulated anisotropic thermal conductivity solid transport In the OpenFOAM foundation branch (openfoam.org) since OpenFOAM-11: Quote:
I don't know if this matches your needs, but it's probably worth checking. I hope this helps, Yann |
anisotropic material, thermophysical properties |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
