how to add the heatsource with fvOptions (The OpenFOAM Foundation edition) |
LIYAFEI
Rep Power: 4 ![]() |
Hello everyone
I wanna add a heat source in the region heater. But with the new edition openfoam11, the code is different from before. It is a ring heater with volume 0.03 cm3 and power 1kW . So I write the code as follow: heatSource { type semiImplicitSource; active true; selectionMode all; volumeMode absolute; sources { e { explicit 1000; implicit 0; } } } and save it in the /constant/heater/fvOptions But from the results, the temperature did not increase. I am not sure where is wrong. Thank you very much |
Yann
Rep Power: 27 ![]() |
In the OpenFOAM foundation branch, fvOptions have been replaced by fvModels and fvConstraints since OpenFOAM-9. Try typing this in your terminal to get more information and examples: Code:
foamInfo heatSource Yann |
heatsource fvoptions |
How to add turbulence model and VOF to a new two-step projection OpenFOAM solver | Msure | OpenFOAM Programming & Development | 2 | November 3, 2022 15:24 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | May 31, 2012 09:07 |
