January 28, 2024, 04:50 |
OF11 convergence issues for MRF zone
Giles Richardson
Rep Power: 14 |
Anyone else encountered solution/convergence problems with MRF zones in OF11 simpleFoam?
There is something wrong since you don't see any rotating surfaces inside the MRF zone. I have been running a case which has been very problematic, but then I reverted to OF10 and it runs fine. I'm wondering if anyone else had similar experience. There is definitely some problem with OF11 MRF. Last edited by ufocfd; February 1, 2024 at 16:22. |
February 8, 2024, 16:12 |
Giles Richardson
Rep Power: 14 |
you need to have MRFnoSlip in the U file (in OF11), instead of fixedValue (in OF10), otherwise it wont work.
convergence, mrf, simplefoam |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 10:49 |
Linear decay - implementation and convergence issues | Diro7 | OpenFOAM Programming & Development | 0 | March 15, 2021 05:53 |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 13:03 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 12:25 |
