January 23, 2024, 15:18 |
Convergence issue on a very simple case
Santi Parera
Rep Power: 7 |
Hey foamers,
I'm not pretty new at OpenFOAM. I have worked on some cases of medium dificulty (non newtonian, turbulence, complex geometry, etc.) in the past. Now I want to work on a simple venturi on a pipe. But first of all, I have started just simulating water flow through a straight pipe. It is a straight pipe diam 50 mm and lenght 300 mm. Boundaries are: - U inlet (zeroGradient) outlet (fixedValue uniform 0 0 1) walls (noSlip) - p inlet (fixedValue uniform 0) outlet and walls (zeroGradient) Mesh is done by blockMesh macro to adapt well to cylinders (extended checkMesh is fully OK). Always in laminar condition, starting with 10 cPs, the simulation (simpleFoam) converges so well. Using final data as 0 and reducing the viscosity to 5 cPs, everything continues to be OK. Again, now with good data as 0, when I reduce viscosity to 1 cPs (water) the p residual starts to climb smoothly performing a pretty constant wave and it ends diverging... Does someone have any idea? Thanks. |
January 24, 2024, 05:31 |
Rep Power: 5 |
Hey!
Can you share the case? |
January 24, 2024, 08:50 |
Troy Snyder
Rep Power: 19 |
January 26, 2024, 11:54 |
#4 | |
Santi Parera
Rep Power: 7 |
Here you can see the .zip of the case: https://drive.google.com/file/d/1EVv...ew?usp=sharing As I said, pretty simple. I have done everything with a p residual set of 0.001. If I do it with normal 0.01 it becomes even worse. |
March 23, 2024, 16:03 |
Santi Parera
Rep Power: 7 |
Hi Troy,
As you said, turbulence model was required. With the straight pipe I have been able to solve it, but when I add just a seondary inlet orthogonal to that pipe, convergence problems appear again. In attached the full case already run: https://drive.google.com/file/d/1IYn...ew?usp=sharing |
axial compressor mass flow convergence issue | jyotir | SU2 | 5 | July 5, 2024 10:06 |
Issue setting up a case with periodic boundaries | sampy | CONVERGE | 12 | February 10, 2023 15:29 |
Continuity convergence issue on a 3d wing | Nick R | FLUENT | 19 | April 6, 2020 15:52 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
Disabling SIMPLE convergence check in simpleControl.H | Mojtaba.a | OpenFOAM Running, Solving & CFD | 0 | August 8, 2012 18:31 |
