January 20, 2024, 07:16 |
MapField for different patch and mesh size
Saeed Jamshidi
Rep Power: 8 |
Hello all,
I have simulated my case in openfoam with the non staggered mesh. However, I'm going to use mapField utility to map for example velocity field on a rectangular staggered mesh. How can I do that? Is it possible?! Thank you in advance. Last edited by saeed jamshidi; January 21, 2024 at 03:02. |
January 20, 2024, 07:28 |
ONESP-RO
Rep Power: 5 |
How did you run an OpenFOAM case with a non-staggered mesh?
Don't keep making the same mistakes. Try to make new mistakes. |
January 20, 2024, 08:37 |
Saeed Jamshidi
Rep Power: 8 |
Ok, it was my bad explanation.
Let's consider this case in which you've modelled your case with the following mesh: layeraddition_snappy.png now you are goiing to map the velocity field to the following mesh: 400px-Cube_case_base_mesh.jpg The question is how it can be performed? |
January 20, 2024, 09:34 |
ONESP-RO
Rep Power: 5 |
Try to follow the steps in this post:
How to mapfields If that does not work for some reason, report the error message here. Regards
January 20, 2024, 11:49 |
Saeed Jamshidi
Rep Power: 8 |
Dear NotOverUnderated,
Thank you for the reply. I am beginner in mapfield utility, and I need more details in order to handle my case. Could you provide me some more information regarding the procedures? Best |
January 20, 2024, 13:28 |
Saeed Jamshidi
Rep Power: 8 |
I made some progress...
However, I have come across an error about number of target cells: Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/target$ mapFields -consistent -sourceTime 'latestTime' ../source/ /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : mapFields -consistent -sourceTime latestTime ../source/ Date : Jan 20 2024 Time : 21:54:10 Host : DESKTOP-TK3D7CI PID : 606 I/O : uncollated Case : /mnt/e/OpenFoam/Run/target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/mnt/e/OpenFoam/Run" "source" Target: "/mnt/e/OpenFoam/Run" "target" Create databases as time Source time: 0 Target time: 0.2 Create meshes Source mesh size: 668000 Target mesh size: 11200 --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) Incompatible meshes: different number of patches, fromMesh = 7, toMesh = 5 From Foam::meshToMesh0::meshToMesh0(const Foam::fvMesh&, const Foam::fvMesh&) in file meshToMesh0/meshToMesh0.C at line 134. FOAM exiting why? It isn't possible to map from fine mesh to course mesh? |
January 20, 2024, 17:42 |
ONESP-RO
Rep Power: 5 |
Hi Saeed,
as far as I know, mapFields works perfectly fine with mesh with different size. I think the error you're getting is related to the number of patches which is different between the source case and the target case. I myself used mapFields only in some simple cases. If you're interested to get a quick overview about this utility check this video by József Nagy: https://youtu.be/qUMPdkvKBS8 I can find this thread that I think is related to your case: mapFields with different number of patches I hope this helps. Regards
January 21, 2024, 01:53 |
Saeed Jamshidi
Rep Power: 8 |
NotOverUnderated thanks again.
Yes, it was because of patch issues and I am doing map with different sizes and patches. However, I tried different commands for executation of mapField; case 1: Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/Target$ mapFields -consistent -sourceTime 'latestTime' ../source/ /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : mapFields -consistent -sourceTime latestTime ../source/ Date : Jan 21 2024 Time : 09:50:20 Host : DESKTOP-TK3D7CI PID : 603 I/O : uncollated Case : /mnt/e/OpenFoam/Run/Target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/mnt/e/OpenFoam/Run" "source" Target: "/mnt/e/OpenFoam/Run" "Target" Create databases as time Source time: 0 Target time: 0.2 Create meshes Source mesh size: 668000 Target mesh size: 11200 --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) Incompatible meshes: different number of patches, fromMesh = 7, toMesh = 6 From Foam::meshToMesh0::meshToMesh0(const Foam::fvMesh&, const Foam::fvMesh&) in file meshToMesh0/meshToMesh0.C at line 134. FOAM exiting Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/Target$ mapFields -consistent -sourceTime 'latestTime' ../source/ -parallelSource /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : mapFields -consistent -sourceTime latestTime ../source/ -parallelSource Date : Jan 21 2024 Time : 10:01:35 Host : DESKTOP-TK3D7CI PID : 616 I/O : uncollated Case : /mnt/e/OpenFoam/Run/Target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/mnt/e/OpenFoam/Run" "source" Target: "/mnt/e/OpenFoam/Run" "Target" Create databases as time Create target mesh Target mesh size: 11200 Source processor 0 Source time: 0.2 Target time: 0.2 mesh size: 111513 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch outlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch top has no faces. Not performing mapping for it. Mapping fields for time 0.2 Source processor 1 Source time: 0.2 Target time: 0.2 mesh size: 111371 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch inlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch outlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch top has no faces. Not performing mapping for it. Mapping fields for time 0.2 Source processor 2 Source time: 0.2 Target time: 0.2 mesh size: 111116 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch inlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch top has no faces. Not performing mapping for it. Mapping fields for time 0.2 Source processor 3 Source time: 0.2 Target time: 0.2 mesh size: 111154 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch outlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch bottom has no faces. Not performing mapping for it. Mapping fields for time 0.2 Source processor 4 Source time: 0.2 Target time: 0.2 mesh size: 111296 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch inlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch outlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch bottom has no faces. Not performing mapping for it. Mapping fields for time 0.2 Source processor 5 Source time: 0.2 Target time: 0.2 mesh size: 111550 --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch inlet has no faces. Not performing mapping for it. --> FOAM Warning : From void Foam::meshToMesh0::calcAddressing() in file meshToMesh0/calculateMeshToMesh0Addressing.C at line 148 Source patch bottom has no faces. Not performing mapping for it. Mapping fields for time 0.2 End Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/Target$ mapFields -sourceTime 'latestTime' ../source/ -parallelSourc e /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : mapFields -sourceTime latestTime ../source/ -parallelSource Date : Jan 21 2024 Time : 10:10:56 Host : DESKTOP-TK3D7CI PID : 619 I/O : uncollated Case : /mnt/e/OpenFoam/Run/Target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/mnt/e/OpenFoam/Run" "source" Target: "/mnt/e/OpenFoam/Run" "Target" Create databases as time Create target mesh Target mesh size: 11200 Source processor 0 Source time: 0.2 Target time: 0.2 mesh size: 111513 Mapping fields for time 0.2 Source processor 1 Source time: 0.2 Target time: 0.2 mesh size: 111371 Mapping fields for time 0.2 Source processor 2 Source time: 0.2 Target time: 0.2 mesh size: 111116 Mapping fields for time 0.2 Source processor 3 Source time: 0.2 Target time: 0.2 mesh size: 111154 Mapping fields for time 0.2 Source processor 4 Source time: 0.2 Target time: 0.2 mesh size: 111296 Mapping fields for time 0.2 Source processor 5 Source time: 0.2 Target time: 0.2 mesh size: 111550 Mapping fields for time 0.2 End |
January 21, 2024, 01:59 |
#9 |
Saeed Jamshidi
Rep Power: 8 |
By the way this is my mapFieldDict:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object mapFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // patchMap ( ); cuttingPatches ( ); // ************************************************************************* // Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/source$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Jan 21 2024 Time : 10:28:06 Host : DESKTOP-TK3D7CI PID : 623 I/O : uncollated Case : /mnt/e/OpenFoam/Run/source nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Mesh stats points: 740740 faces: 2076200 internal faces: 1931800 cells: 668000 faces per cell: 6 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 668000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1600 1771 ok (non-closed singly connected) outlet 1600 1771 ok (non-closed singly connected) cylinder 2400 2640 ok (non-closed singly connected) top 2600 2871 ok (non-closed singly connected) bottom 2600 2871 ok (non-closed singly connected) back 66800 67340 ok (non-closed singly connected) front 66800 67340 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking geometry... Overall domain bounding box (-0.4 -0.4 -0.01) (1 0.4 0.01) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.41575e-18 -7.09869e-18 1.66212e-14) OK. Max cell openness = 9.0192e-16 OK. Max aspect ratio = 65.3413 OK. Minimum face area = 1.5997e-08. Maximum face area = 0.000174079. Face area magnitudes OK. Min volume = 3.20006e-11. Max volume = 3.48158e-07. Total volume = 0.0223749. Cell volumes OK. Mesh non-orthogonality Max: 44.1889 average: 7.86983 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.434082 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/Target$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : Jan 21 2024 Time : 10:27:14 Host : DESKTOP-TK3D7CI PID : 621 I/O : uncollated Case : /mnt/e/OpenFoam/Run/Target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches - from boundary section Creating block mesh topology Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list (topological search)... Deleting polyMesh directory "constant/polyMesh" Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale (1 1 1) Block 0 cell size : i : 0.01 .. 0.01 j : 0.01 .. 0.01 k : 0.02 .. 0.02 There are no merge patch pairs Writing polyMesh with 0 cellZones ---------------- Mesh Information ---------------- boundingBox: (-0.4 -0.4 -0.01) (1 0.4 0.01) nPoints: 22842 nCells: 11200 nFaces: 45020 nInternalFaces: 22180 ---------------- Patches ---------------- patch 0 (start: 22180 size: 80) name: inlet patch 1 (start: 22260 size: 80) name: outlet patch 2 (start: 22340 size: 140) name: top patch 3 (start: 22480 size: 140) name: bottom patch 4 (start: 22620 size: 11200) name: front patch 5 (start: 33820 size: 11200) name: back End Last edited by saeed jamshidi; January 21, 2024 at 03:02. |
January 21, 2024, 03:40 |
#10 |
Saeed Jamshidi
Rep Power: 8 |
Hi again,
I found the problem. The contents of the 0 folder must be inside the latest time (0.2 second) folder. Code:
saeedfoam@DESKTOP-TK3D7CI:/mnt/e/OpenFoam/Run/Target$ mapFields -sourceTime 'latestTime' ../source/ -parallelSource /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112 Arch : "LSB;label=32;scalar=64" Exec : mapFields -sourceTime latestTime ../source/ -parallelSource Date : Jan 21 2024 Time : 11:54:25 Host : DESKTOP-TK3D7CI PID : 762 I/O : uncollated Case : /mnt/e/OpenFoam/Run/Target nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/mnt/e/OpenFoam/Run" "source" Target: "/mnt/e/OpenFoam/Run" "Target" Create databases as time Create target mesh Target mesh size: 11200 Source processor 0 Source time: 0.2 Target time: 0.2 mesh size: 111513 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U Source processor 1 Source time: 0.2 Target time: 0.2 mesh size: 111371 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U Source processor 2 Source time: 0.2 Target time: 0.2 mesh size: 111116 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U Source processor 3 Source time: 0.2 Target time: 0.2 mesh size: 111154 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U Source processor 4 Source time: 0.2 Target time: 0.2 mesh size: 111296 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U Source processor 5 Source time: 0.2 Target time: 0.2 mesh size: 111550 Mapping fields for time 0.2 interpolating nut interpolating p interpolating k interpolating omega interpolating U End
Edit: keep in mind you should execute blockMesh in target directory before running the above command. Last edited by saeed jamshidi; January 21, 2024 at 07:15. |
January 21, 2024, 07:08 |
#11 |
Saeed Jamshidi
Rep Power: 8 |
That was the case where you can do maping for a specific period of time, now I would like to do maping over runtime through the following utility:
mapFields1 { // Mandatory entries (unmodifiable) type mapFields; libs (fieldFunctionObjects); // Mandatory (inherited) entries (runtime modifiable) fields (<field1> <field2> ... <fieldN>); mapRegion coarseMesh; mapMethod cellVolumeWeight; consistent true; // Optional entries (runtime modifiable) // patchMapMethod direct; // AMI-related entry // enabled if consistent=false // patchMap (<patchSrc> <patchTgt>); // cuttingPatches (<patchTgt1> <patchTgt2> ... <patchTgtN>); // Optional (inherited) entries region region0; enabled true; log true; timeStart 0; timeEnd 1000; executeControl timeStep; executeInterval 1; writeControl timeStep; writeInterval 1; } I have adopted it inside my controlDict: Code:
functions { mapFields1 { type mapFields; libs (fieldFunctionObjects); mapRegion Target; mapMethod cellVolumeWeight; consistent no; patchMap (); cuttingPatches (); fields ( U p ); executeControl writeTime; writeControl writeTime; } } How can I adopt this part for my case? Regards |
January 21, 2024, 07:31 |
#12 |
ONESP-RO
Rep Power: 5 |
I think you need to create a region. I have never done that myself before but I believe this is easy when checking the cavityMappingTest tutorials.
$FOAM_TUTORIALS/tutorials/incompressible/icoFoam/cavityMappingTest Code:
# create the coarse mesh blockMesh -dict system/blockMeshDict.coarse # move the coarse mesh to its own folder mv constant/polyMesh constant/coarseMesh # create the fine mesh blockMesh -dict system/blockMeshDict.fine
January 21, 2024, 12:16 |
#13 |
Saeed Jamshidi
Rep Power: 8 |
Thanks for the information.
// Optional (inherited) entries region region0; However, in the cavityMappingTest tutorial the mapping over runtime has not mentioned. I would appreciate any help regarding this matter as well as any idea for mapping all of the time steps with postProcess utility. Thanks. Last edited by saeed jamshidi; January 21, 2024 at 13:56. |
January 21, 2024, 15:38 |
#14 |
ONESP-RO
Rep Power: 5 |
In your question you're asking about mapRegion keyword not region keyword.
January 21, 2024, 15:40 |
#15 |
Saeed Jamshidi
Rep Power: 8 |
I am working on it, and it gave me some satisfactory feedback.
Tomorrow I will share my findings. Best |
January 22, 2024, 07:05 |
#16 | |
Saeed Jamshidi
Rep Power: 8 |
I followed the steps of cavityMappingTest, and finally became successful to perform mapping over runTime. However, I have come across another isssue with that. Original result:Screenshot (263).jpg The interpolated results:Screenshot (264).jpg & Screenshot (265).jpg As you can see, when I use point data illustration, every thing got messed up! However, mapping of cell data illustration seems good. Does it depend on the factors of: Quote:
January 23, 2024, 03:21 |
#17 |
Saeed Jamshidi
Rep Power: 8 |
Any idea?
January 23, 2024, 11:36 |
#18 |
Saeed Jamshidi
Rep Power: 8 |
Finally, I found the problem.
The point is I should assign empty type to all patches in the blockMeshDict.course for my case. Code:
boundary ( inlet { type empty; faces ( (0 4 7 3) ); } outlet { type empty; faces ( (1 5 6 2) ); } top { type empty; faces ( (3 2 6 7) ); } bottom { type empty; faces ( (0 1 5 4) ); } front { type empty; faces ( (0 1 2 3) ); } back { type empty; faces ( (4 5 6 7) ); } ); Screenshot (276).jpg & Screenshot (277).jpg |
Using mapFields on a moving grid | Reptider | OpenFOAM Running, Solving & CFD | 1 | June 28, 2021 05:10 |
IBM grid recognition in foam-extend 4.1 | Guanzhu | OpenFOAM | 0 | January 25, 2021 21:23 |
Grid Check Script | pdp.aero | SU2 | 2 | April 23, 2015 01:54 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
