Simulation with turbulence modelling converges but laminar simulation does not
Like Tree1Likes
  • 1 Post By superlegit
Old   December 29, 2023, 12:06
Default Simulation with turbulence modelling converges but laminar simulation does not
Timothy
superlegit is on a distinguished road
I've been trying to run a 2D single-phase simulation on a relatively simple geometry using Simplefoam. Convergence can be arrived at when I incorporate the use of the k-epsilon turbulence model, whether turbulence is turned on or off in the turbulenceProperties file, but when no turbulence model is used, I either run into a floating point exception or the residuals oscillate and fail to fall to the desired level.
The geometry is here: https://imgur.com/a/ErOuaUP
The boundary conditions for U are:
  • Inlet: fixedvalue, uniform (2 0 0)
  • walls: noslip
  • outlet: pressureInletOutletVelocity
The boundary conditions for P are
  • Inlet: zerogradient
  • walls: zerogradient
  • outlet: totalpressure, p0=0
The case folder is here: https://drive.google.com/drive/folde...usp=drive_link
I have tried changing the mesh resolution, reducing the timestep, changing to a fixedvalue pressure outlet BC, and decreasing the inlet velocity to lower the Reynolds number of the ingoing flow but to no avail. I would appreciate any advice or guidance regarding this.
Thank you
superlegit is offline   Reply With Quote
Old   January 7, 2024, 10:34
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Do you mean laminar flow?
Please try this:
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
saeed jamshidi is offline   Reply With Quote
Old   January 11, 2024, 14:29
Timothy
Thanks. Decreasing the relaxation factors by itself didn't work, but lowering the velocity and characteristic length until the flow regime was laminar (Re=2000), together with lowering the relaxation factors, worked
saeed jamshidi likes this.
Laminar simulation of turbulent interfoam tutorial case doesn't finish finn_amann OpenFOAM Running, Solving & CFD 0 May 6, 2022 10:03
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background pchoopanya Main CFD Forum 4 May 10, 2018 12:05
Flow Around a Cricket Ball - Turbulence Modelling Approaches? Brock17 Main CFD Forum 0 April 10, 2017 09:21
Turbulence modelling for bubble column in twoPhaseEulerFoam hester OpenFOAM Running, Solving & CFD 2 February 10, 2015 12:42
Turbulence Intensity Vs CFD Simulation Apple L S Chan Main CFD Forum 3 December 15, 1998 18:28
