combustion does not occur with reactingFoam
Like Tree1Likes
  • 1 Post By tas38
Old   December 1, 2023, 13:35
Default combustion does not occur with reactingFoam
Edoardo
Edoardo1993 is on a distinguished road
I am trying to simulate a flammable gas flow in atmosphere with reactingFoam. You can find the whole case directory attached at the end.
If I do not ignite the gas (/constant/combustionProperties --> active off and /constant/chemistryProperties --> chemistry off) the gas leak is totally diffusive and results are good.
However, if I try to ignite the flammable gas (/constant/combustionProperties --> active on and /constant/chemistryProperties --> chemistry on) the reaction does not occur. Therefore the results are exactly the same as withouth ignition.
The reaction is a single-step reaction, implemented in /constant/reactionGRI.
reactionGRI
elements
species
4
H2
O2
H2O
N2
reactions
    un-named-reaction-2
        type            irreversibleinfiniteReaction;
        reaction        "2H2 + O2 + 3.79N2 = 2H2O + 3.79N2";
chemistryProperties
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      chemistryProperties;
chemistryType
    chemistrySolver   ode;
    chemistryThermo   psi;
    TDAC              off;
initialChemicalTimeStep 1e-07;
chemistry       on;
odeCoeffs
    solver          seulex;  // Rosenbrock34, seulex or rodas23
    absTol          1e-12;
    relTol           1e-7;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      combustionProperties;
combustionModel  EDC;
active  on;
EDCCoeffs
    version v2005;
thermophysicalProperties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture        reactingMixture; //singleStepReactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
inertSpecie N2;
chemistryReader foamChemistryReader;
foamChemistryFile "<constant>/reactionsGRI";
foamChemistryThermoFile "<constant>/thermo.compressibleGasGRI";
dpdt false;
I have the following question:
1) Why does the reaction not occur?
2) Is irreversibleinfiniteReaction in /constant/reactionGRI correct? Maybe is it not fast enough to show something in a short time?
3) In /constant/thermophysicalProperties should be selected mixture reactingMixture or singleStepReactingMixture?
4) Could be the problem the lack of ignition?
Really thank for your help.
Edoardo1993 is offline   Reply With Quote
Old   December 4, 2023, 15:33
abdikerim kurbanaliev
kerim is on a distinguished road
Try to use another turbulence model. For example RNG instead of standard k-e-model.
Please see this post
reactingFoam SandiaD_LTS tutorial error.
May be it will help you.
Good luck!
kerim is offline   Reply With Quote
Old   December 4, 2023, 21:11
Edoardo
Good luck!
@kerim thank you for your answer. I followed your tips and switched standard k-eps model to RNG k-eps model in turbulenceProperties... but the results do not show any combustion, only diffusion.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties;
simulationType   RAS;
RAS
    RASModel        RNGkEpsilon;
    kEpsilonCoeffs
        Prt 1;
    turbulence      on;
    printCoeffs     on;
Old   December 5, 2023, 14:59
Troy Snyder
tas38 is on a distinguished road
Edoardo1993,
Per your original post, I would suggest changing the reaction in reactionsGRI from irreversibleinfiniteReaction to irreversibleArrheniusReaction. You can then adjust the Arrhenius rate constants and activation temperature until you get a reaction. If ignition/combustion still does not occur, re-running with alternative RAS models per Kerim is also advised.
Notably, irreversibleArrheniusReaction is only used in conjunction with LES turbulence in the combustion tutorials.
Edoardo1993 likes this.
tas38 is offline   Reply With Quote
Old   December 5, 2023, 16:39
Edoardo
Originally Posted by tas38 View Post
Edoardo1993,
Thank you tas38. I did not know about LES and irreversibleinfiniteReaction.
Now, my reaction file is:
reactions
    un-named-reaction-2
        type         irreversibleArrheniusReaction;
        A        5.2e16;
        beta     0;
        Ta       14906;
Reaction does not occur yet, with both standard k-eps and RNG k-eps models. I think the problem is the lack of ignition, because there are not hot spots in the domain.
Old   December 6, 2023, 10:13
Troy Snyder
Edoardo1993,
Yes, you could try adding an ignition source (small box with high temperature) using setFieldsDict containing a boxToCell region as in DLR_A_LTS.
However, if I recall, the EDC model should not require a direct ignition source. Combustion is initiated simply due the presence of turbulence, i.e. k and \epsilon.
I just noticed in your combustionProperties file you have active on;, however, I believe this should be active true;. Not sure if no vs. true makes a difference, but I would try this first.
Old   December 7, 2023, 18:42
Edoardo
Edoardo1993,
tas38, thank you for your kind help.
I knew that active true and on are the same keyword.
Regarding ignition with EDC model, I created another directory for test and the combustion starts only when the flammable flow touches an hot spot, in my case a wall with T=1000K (probably you can get similar result with setFieldDict). I don't see any reaction to occur when this wall is cold.
What do you mean with "Combustion is initiated simply due the presence of turbulence, i.e. k and \epsilon"? The greater k and epsilon, the faster the reaction?
Old   December 16, 2023, 10:48
Edoardo
Hello. I hope someone can help me because I am still stucked with this issue.
I finally managed to ignite the gas with fvOptions setting some cells at 1200K. The problem is the simulation is running only when using CH4.
As soon as I switch the gas to H2 (changing the reaction with "H2 + 2O2 = 2H2O" and the thermo.compressibleGas ), the simulation starts but it stops because of several errors..
elements
O
C
H
N
species
    O2
    H2O
    CH4
    CO2
    N2
reactions
    methaneReaction
        reaction "CH4 + 2O2 = CO2 + 2H2O";
        A        5.2e16;
        beta     0;
        Ta       14906;
Furthermore, I have another question. I attempted to integrate the GRI reactions, which I found in the SANDIAD_LTS tutorial, into the working model with CH4. Why does the reaction occur with the single-step reaction but not with the GRIMECH file?"
Old   January 3, 2024, 01:47
Han Yu
Han Yu is on a distinguished road
Hello. I want to simulate a combustion model through EDC model based on reactingFoam. Could you please show me a tutorial about EDC implementation? Thank you very much!
Han Yu is offline   Reply With Quote
combustion, hydrogen, ignition, reactingfoam, reaction
OpenFoam Combustion SIG dlahaye OpenFOAM Announcements from Other Sources 0 August 14, 2023 12:39
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 11:23
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 10:10
Constant Volume Combustion with reactingFoam Alish1984 OpenFOAM Running, Solving & CFD 2 May 8, 2011 09:51
