Liquid phase accumulating on atmosphere boundary
Like Tree1Likes
  • 1 Post By mortezahdr
Old   November 17, 2023, 10:01
Default Liquid phase accumulating on atmosphere boundary
Morteza
mortezahdr is on a distinguished road
I have a 3D domain initially filled with air. Based on the figure below, water is injected with a certain velocity from top left to the domain and moves through the domain. I am using interFoam. The figure shows iso-surface of alpha.water = 0.5. The boundary specified is atmosphere. The water is being accumulated after hitting that boundary.
My question is, what kind of boundary condition for p_rgh, U, and alpha.water should I use, so that the water leaves the domain instead of being accumulated after hitting the atmosphere boundary. Currently, these BCs are as follows:
U:
inlet
type flowRateInletVelocity;
volumetricFlowRate constant 7.22E-06;
atm
type inletOutlet;
inletValue uniform 0;
value uniform 0;
_______________________________________
p_rgh:
inlet
type fixedFluxPressure;
value uniform 0;
atm
type totalPressure;
p0 uniform 0;
alpha.water:
inlet
type fixedValue;
value uniform 1;
atm
type inletOutlet;
value uniform 0;
Thank you.
mortezahdr is offline   Reply With Quote
Old   November 21, 2023, 14:05
Morteza
Answer to my question: On the specified boundary,
U:
type inletOutlet;
inletValue $internalField;
value $internalField;
p:
value uniform 0;
alpha.water:
type zeroGradient;
I would like to thank you all for sharing your thoughts on this!!
saidc. likes this.
atmosphere, boundary conditions, interfoam, openfoam
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 16:36
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
