Menter's wall BC for Omega
Like Tree3Likes
  • 1 Post By arjun
  • 1 Post By NotOverUnderated
  • 1 Post By arjun
Old   November 11, 2023, 11:14
Default Menter's wall BC for Omega
Saeed Jamshidi
saeed jamshidi is on a distinguished road
I'm going to dive into K-omega SST turbulence model, and I'v noticed about Menter's wall BC for Omega.
Would you please help me to clarify nu and y?
y is the first cell hight close to the wall not y+?
Is nu=kinematic viscosity?, for example (nu_water=1e-6) otherwise what is the kinematic viscosity at the wall?
thanks.
omega
type fixedValue;
value uniform (calculated with Menter's recommended wall BC, i. e.
omegawall=60*nu/(beta*y^2), with nu=kinematic viscosity at the wall,
beta=0.075 and y=normal distance between the first fluid node and the nearest wall);
saeed jamshidi is offline   Reply With Quote
Old   November 11, 2023, 16:56
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Everything seems good except the factor would be 6 and not 60.
arjun is offline   Reply With Quote
Old   November 12, 2023, 01:29
Saeed Jamshidi
Dear arjun, thank you for the reply.
The formula is as follows:
omega_wall = 10 * 6 * nu / ( 0.075 * y^2 )
So, you confirm that y is the first cell hight and nu is the kinematic viscosity?
Besides, I would appreciate it if you verify my K, omega and nut BCs on the wall for y+=1;
omega:
    wall
        type             fixedValue;
        value          uniform  63775; //according menter BC.
K:
    wall
        type            fixedValue;
        value           uniform 1e-12;
nut:
     wall
        type fixedValue;
	value uniform 0;
Currently, I am pretty sure about K & omega BC types and values, nevertheless, I have doubt for nut type because I've seen in CFD online some threads, calculated type is considered on the wall.
Old   November 12, 2023, 14:54
Arjun
Nu and y are what you said.
The factor of 10 seems arbitrary to me but if its working for them then who am i to argue.
This seems to be something people are doing differently.
saeed jamshidi likes this.
Old   January 15, 2024, 08:08
NotOverUnderated's Avatar
ONESP-RO
NotOverUnderated is on a distinguished road
That factor is not arbitrary. It is in the original paper of menter [1]:
Reference:
[1] F. R. Menter, ‘Two-equation eddy-viscosity turbulence models for engineering applications’, AIAA Journal, vol. 32, no. 8, pp. 1598–1605, 1994, doi: 10.2514/3.12149.
Don't keep making the same mistakes. Try to make new mistakes.
NotOverUnderated is offline   Reply With Quote
Old   January 15, 2024, 10:26
Arjun
Reference:
Its arbitrary in reference paper too. He never derived how he came to that factor. Besides other people use other values. StarCCM uses 2.5 and not 10.
Do you have a paper that derives that factor 10 and shows that it is not something that author came up with and have defite value of 10.
JBeilke likes this.
Old   January 15, 2024, 10:36
Saeed Jamshidi
Thank you for your opinions.
Yeah, it's kind of controversial issue.
However, I saw wolf dynamics tutorial, and it was declared that omega value just on the wall could be a large value.
Old   January 15, 2024, 10:40
Arjun
Yes, different people do different things. I guess based on their experience and ideas. I prefer 2.5 as value as it seems to produce good results.
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall JayDeeUU OpenFOAM Pre-Processing 16 July 22, 2021 22:17
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
