Turbulent Boundary Conditions with Slip Walls
Like Tree3Likes
  • 2 Post By Yann
  • 1 Post By shock77
Old   November 6, 2023, 10:59
Default Turbulent Boundary Conditions with Slip Walls
shock77 is on a distinguished road
Usually I always had noSlip walls when running numerical simulations. Now, I have a case where I need to apply slip boundary conditions. I wonder what boundary condition I should use for k, omega and alphat when using the k-omega-SST model. Do I use zeroGradient or slip for those?
Kind regards,
Shock77
shock77 is offline   Reply With Quote
Old   November 7, 2023, 15:01
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Quick answer:
I think the below condition is the answer, but I'm not sure:
    wall
        type            slip;
this is true for K & omega.
saeed jamshidi is offline   Reply With Quote
Old   November 8, 2023, 04:27
Thank you for your reply and input!
I couldnt find anyone who uses slip in combination with turbulence models. It feels also kind of weird to be honest and counter intuitive. Have you ever used this combination?
Old   November 8, 2023, 06:01
Saeed Jamshidi
Yes, I have.
When I want to simulate flow over cylinder (3D) I consider slip BC for the top & Bottom as well as for the front & Back with K-omega SST.
Besides, you can have a look at the motorbike tutorial in simpleFoam, just focus on BCs.
\\wsl.localhost\Ubuntu18.04\home\saeedfoam\OpenFOAM\tutorials\incompressible\simpleFoam\motorBike
Good luck.
Old   November 9, 2023, 05:26
Good to know, thank you!
In the tutorial they use wall functions. Do you mean another tutorial by any chance?
Old   November 9, 2023, 05:37
Saeed Jamshidi
I have read some materials and found that utilization of wall functions is a merit, because you set yplus abouve 30 and it reduces computational time cost. However, I'm looking for the tutorials without treating walls with wall functions to understand the boundary conditions of walls for k, omega and nut.
Old   November 9, 2023, 05:41
So is there any tutorial that uses slip for k, omega or epsilon?
Old   November 9, 2023, 05:58
Yann
Yann will become famous soon enoughYann will become famous soon enough
You can check the tutorials, for instance:
grep -r "slip" $FOAM_TUTORIALS | grep "/omega"
Cheers,
Yann
saeed jamshidi and shock77 like this.
Yann is offline   Reply With Quote
Old   November 9, 2023, 05:59
Saeed Jamshidi
As you can see from motorbike tutorial, upperWall was considered as slip:
upperWall
    type slip;
frontAndBack
    type slip;
for example, have a look at part of k :
    lowerWall
        type            kqRWallFunction;
        value           $internalField;
    motorBikeGroup
    #include "include/frontBackUpperPatches"
wall functions are used when we have noslip BC (such as on motorbike or lower wall), while in slip condition (upper wall) we assign slip for k (assigned by include command), omega or epsilon.
upper wall actually is not a real wall and in real world does not exist. we just consider it in our simulation.
So, you should consider this in all k, omega or epsilon dictionaries in zero folder:
Wall
type slip;
Old   November 9, 2023, 06:07
Saeed Jamshidi
Cheers,
Yann
Hi Yann,
Have you ever seen a tutorial without using wall functions on walls? specially for k-omega sst model.
Thanks
Old   November 14, 2023, 05:21
Cheers,
Yann
Thank you very much! Seems like there is no usage of slip for omega or k in the tutorials.
Old   November 14, 2023, 05:24
upperWall
    type slip;
frontAndBack
    type slip;
    lowerWall
    motorBikeGroup
Wall
type slip;
I cannot see a slip assigned to k in the tutorials or in the code you copied. Interestingly, my tutorial is different from yours (I am using Openfoam 5). For U I get:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
#include        "include/initialConditions"
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    //- Set patchGroups for constraint patches
    #includeEtc "caseDicts/setConstraintTypes"
    #include "include/fixedInlet"
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    lowerWall
        type            fixedValue;
    motorBikeGroup
        type            noSlip;
For k:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $turbulentKE;
boundaryField
    //- Define inlet conditions
    outlet
        type            inletOutlet;
        inletValue      $internalField;
    lowerWall
    motorBikeGroup
Old   November 14, 2023, 05:30
Saeed Jamshidi
Please have a look at your 0/ include folder.
You will see some BCs there.
Allways they are included to your K or U .... by #include "include/frontBackUpperPatches".
I am using OpenFoam v2112.
Old   November 14, 2023, 05:34
Ohhh now I see it, thank your very much again!
saeed jamshidi likes this.
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
