trying why my runs diverge - simple case I built
Like Tree1Likes
  • 1 Post By Tobermory
Old   October 28, 2023, 15:55
Default trying why my runs diverge - simple case I built
chemotkbilo is on a distinguished road
So I have the following case that I built, the mesh lis ok (used checkMesh), and developed the the required constants. However, when I run simpleFoam or foamRun, it starts to solve up to certain point and then it starts to produce nan.
For example, see below
HTML Code:
[CODE]SmoothSolver:  Solving for Ux, Initial residual = 0.91362581, Final residual = 9.1691167e-06, No Iterations 36
smoothSolver:  Solving for Uy, Initial residual = 0.97344182, Final residual = 7.8785232e-06, No Iterations 34
smoothSolver:  Solving for Uz, Initial residual = 0.99999992, Final residual = 8.4295095e-06, No Iterations 37
GAMG:  Solving for p, Initial residual = 1, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan
GAMG:  Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000
time step continuity errors : sum local = nan, global = nan, cumulative = nan
smoothSolver:  Solving for epsilon, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000
ExecutionTime = 15.673765 s  ClockTime = 15 s
Courant Number mean: nan max: nan
Time = 0.0469628s
smoothSolver:  Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver:  Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1000
[/CODE]
My files are provided below - any help would be appreciated.
chemotkbilo is offline   Reply With Quote
Old   October 29, 2023, 14:08
Tobermory will become famous soon enough
Looks like you are trying to run as a transient simulation. Try changing over to steady state:
- in fvSchemes, change ddtSchemes default from Euler to steadyState
- in fvSolution, comment out the PIMPLE section and add the following:
SIMPLE
    nNonOrthogonalCorrectors 0;
    consistent      yes;
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon)" 1e-3;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        epsilon         0.7;
- in controlDict, change deltaT to 1
Now run with simpleFoam, and this should converge/behave nicely. Good luck!
chemotkbilo likes this.
Tobermory is offline   Reply With Quote
FSI. simple pipe case crashes Svensen ANSYS 0 November 19, 2018 13:59
Dambreak case can't be simulated by the simple coupled level set and vof (sclsvof) saatt OpenFOAM Running, Solving & CFD 1 January 21, 2018 18:40
Simple test case for k-epilon model mathletic Main CFD Forum 2 September 28, 2012 04:04
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Need help on simple CFD case. (using CFD-ACE+) Sean Main CFD Forum 1 September 30, 2005 11:05
