buoyantBoussinesqSimpleFoam time step continuity error |
Jacob
Rep Power: 3 ![]() |
Greetings,
I have a time step continuity error appearing after p_rgh. The residual and number of iterations keeps increasing until it breaks. I've been trying to figure it out for awhile now. Any help would greatly be appreciated. Here is what I have tried so far: - increasing and decreasing the mesh resolution - decreasing deltaT down to 1e-9 - change the p_rgh solver - reviewed boundary conditions - using a different geometry - decreasing temperature delta between the fluid and the wall - decreasing the velocity of the fluid (makes it take longer to break) About the model: Looking at the heat transfer through the wall of a single pipe. It consists of an inlet, outlet and pipe wall. The pipe follows a half circle in shape. OpenFoam files https://drive.google.com/drive/folde...usp=drive_link Error Example: Time = 8e-05 DILUPBiCGStab: Solving for Ux, Initial residual = 0.0496474, Final residual = 0.000320209, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.0613424, Final residual = 0.000501452, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.0483784, Final residual = 0.000280833, No Iterations 1 DILUPBiCGStab: Solving for T, Initial residual = 0.0223053, Final residual = 0.000718434, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.0799987, Final residual = 0.00549111, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.0139417, Final residual = 0.00126615, No Iterations 6 DICPCG: Solving for p_rgh, Initial residual = 0.00491635, Final residual = 0.000490945, No Iterations 20 time step continuity errors : sum local = 2.23732e-07, global = -4.54896e-08, cumulative = 2.71372e-07 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.172514, Final residual = 0.00040205, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 0.132612, Final residual = 0.00172569, No Iterations 1 ExecutionTime = 16.35 s ClockTime = 17 s |
Yann
Rep Power: 27 ![]() |
Hello Jacob,
Just to make sure we are on the same line, the time step continuity check is part of the resolution process. You will see it in every solver, for every time step. In the snippet you posted, continuity errors are in the order of 10^-7, which is pretty low. This what is expected. If continuity errors start increasing, this would indicates there is a problem in your simulation. (often related to boundary conditions) Yann |
Jacob
Not sure why my reply did not post but I'll try again.
Correct the keeps growing until it breaks. Here is what it shows when it breaks; Time = 0.01338 DILUPBiCGStab: Solving for Ux, Initial residual = 0.0294298, Final residual = 0.000228221, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.0234604, Final residual = 0.000125468, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.0223239, Final residual = 0.000150431, No Iterations 1 DILUPBiCGStab: Solving for T, Initial residual = 0.000473069, Final residual = 4.52044e-05, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.0289488, Final residual = 0.00274625, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.00567332, Final residual = 0.000556981, No Iterations 10 DICPCG: Solving for p_rgh, Initial residual = 0.00350916, Final residual = 0.000349147, No Iterations 6 time step continuity errors : sum local = 2.08409e+30, global = 9.4385e+29, cumulative = 1.18906e+31 #0 Foam::error: ![]() #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::scalarProduct<double, double>::type Foam::gSumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&, int) at ??:? |
Yann
OK then must probably there might be an issue with the mesh and/or boundary conditions.
I can't access your files so I cannot help more Yann |
Jacob
Yann,
Thank you for being patient with me. The link to the google drive folder should work now. https://drive.google.com/drive/folde...usp=drive_link |
Yann
Thank for the re-upload.
After a quick check:
These changes should fix your issue. Cheers, Yann |
Jacob
Yann,
Thank you so much. I changed those boundary conditions and now it converges. Jacob |
p_rgh, time step cont. error |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
