kOmegaSSTSAS (LES-RANS)
Like Tree1Likes
  • 1 Post By esma
Old   October 22, 2023, 19:07
Default kOmegaSSTSAS (LES-RANS)
esma is on a distinguished road
Hi
I've been trying to use kOmegaSSTSAS in a wind engineering application.
This is actually a great model since this is a hybrid LES-RANS turbulence model that applies RANS kOmegaSST near walls and LES for the rest of the domain where large eddies are of interest in particular in wind engineering.
It appears there are no previous examples provided in the OpenFOAM library and my search through forums didn't end up with any case setup. The thing that puzzled me the most was this turbulence model is subclassed as LES in OpenFOAM (see 1 attached) but when going through the detail description is classified in RAS (see 2). So I struggled at first by setting the model under LES in constant/turbulenceproperties even for a simple model such as a box (see 3) against inlet flow to work. However, when I changed it to RAS it started working and I believe I can see the eddies are formed (see 4). However still in doubt if the settings are correct. Does anyone have experience with such a scaled hybrid model? Should kOmegaSSTSAS be under RAS?. I copy the turbulenceproperties below.
| \\ / O peration | Version: v2206 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType RAS;
RAS
RASModel kOmegaSSTSAS;
turbulence on;
printCoeffs on;
delta vanDriest;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
esma is offline   Reply With Quote
Old   October 30, 2023, 14:16
Saeed Jamshidi
saeed jamshidi is on a distinguished road
If you are going to use kOmegaSSTSAS in the family of Scale Adaptive Simulation (SAS), you should follow as below:
simulationType SAS;
SAS
not RAS model.
This is a kind of turbulent model that I found, please check it.
|  \\    /   O peration     | Version:  v2112                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
simulationType  LES;
LES
    LESModel        kOmegaSSTIDDES;
    printCoeffs     yes;
    turbulence      yes;
    delta           IDDESDelta;
    IDDESDeltaCoeffs
        hmax           maxDeltaxyzCubeRoot;
        maxDeltaxyzCubeRootCoeffs
saeed jamshidi is offline   Reply With Quote
Old   October 30, 2023, 17:39
simulationType SAS;
SAS
not RAS model.
[/CODE]
Thanks, but apparently there is no such thing as "simulationType SAS;" in the turbulent library. It returns the error "Unknown simulation type SAS" followed by "Valid simulationType types: 3(LES RAS laminar).
so it appears the turbulent model types shall be either LES or RAS. I tried the LES as the type with kOmegaSSTSAS model it didn't proceed saying no such model in LES. So I changed it with RAS which appear working.
The IDDES is a detached eddy simulation. Was just wondering about SAS in particular.
Btw, I will try DES as you suggested if still was in doubt about using SAS which looks like it has inherent URANS characteristics rather than LES.
lpz456 likes this.
Old   October 31, 2023, 01:19
Saeed Jamshidi
Dear esma, you were right!
Please look at: https://www.openfoam.com/documentati...urbulence.html
k-omega-SST SAS is a class of LES model.
Old   May 27, 2024, 05:15
Ali Berk Kahraman
abkahraman is on a distinguished road
Hi Esma,
Did it work out for you? I am thinking of trying SAS for my simulations, but there is a lack of information within openfoam framework. Could you share any insights if you have any?
Best Regards,
Ali
abkahraman is offline   Reply With Quote
Sajben Transonic Diffuser Benchmark: RANS is great, struggling with LES CSMDakota SU2 5 October 11, 2023 05:08
particle-laden backward facing step (BFS) using DPMFoam: LES vs RANS atul1018 OpenFOAM Running, Solving & CFD 8 January 4, 2021 07:20
Worse accuracy in LES models than in RANS models dferrando OpenFOAM Running, Solving & CFD 0 August 30, 2017 05:56
Model Switch, RANS to LES? jennap223 STAR-CCM+ 0 July 7, 2015 12:30
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 06:31
