August 18, 2023, 00:31 |
Simple way of simulating heating from sun
Boris
Rep Power: 9 |
I am currently to do a simple case, the tutorial example "simpleCarSolarPanel" from the heattransfer tutorials. In the tuorial, it seems the temperature is constant everywhere in the domain. But what I would like to simulate is actually the temperature in the domain, as well as its effect on the natural convection it generates. I thought of using the "qr" as a an input for heat in my domain, but I can not find how to use any boundary conditions that would let me do that.. Would anyone have experience on that? I do not need a very realistic simulation, just a way of having the boundary cells with a high qr to input heat at a higher rate in the domain, that the ones with a lower qr. Thank you! |
August 18, 2023, 03:55 |
Yann
Rep Power: 27 |
You can replace the zeroGradient temperature BC by something like externalWallHeatFluxTemperature so your walls get heated up with solar radiation. Have a look at the documentation: https://doc.openfoam.com/2306/tools/...uxTemperature/ You can also check the tutorial linked in the documentation. Hope this helps, Yann |
August 18, 2023, 04:15 |
Boris
Rep Power: 9 |
Hi Yann,
Great. Thanks, it seems it sent me on the good direction I now have results, but have some issue still. Namely, I get zone with unrealistic high T°. I tried playing around with the radiation propeties, boundaryRadiationProperties, 0/T, etc. I manage to lower a bit the high T°, but it is still unrealistically high.. I tried to use fvOptions with limitT, but somehow it does not do anything ? I get a Code:
limitTemperature limitTAir Lower limited 0 (0%) of cells, with min limit 290 limitTemperature limitTAir Upper limited 6911 (19.88%) of cells, with max limit 350 limitTemperature limitTAir Unlimited Tmin 299.642 limitTemperature limitTAir Unlimited Tmax 350 but it does not seem to limit it. If anyone had any idea why I get such high temperature, or knows a way to apply the limitT (not the best option I know ), It will be of great help! I am sharing the case here: |
August 18, 2023, 04:52 |
Yann
Rep Power: 27 |
It looks like your limitT is working:
limitTemperature limitTAir Upper limited 6911 (19.88%) of cells, with max limit 350 About the temperature values you get, I guess it must be related to the radiation received, the radiative properties of your walls and the other boundary conditions used in the tutorial. |
August 18, 2023, 04:58 |
Boris
Rep Power: 9 |
Ah, that is peculiar, because when I post-process the case using paraview, I see temperatures way above the limit, as shown in the attached picture (https://imgur.com/a/MjpQIvT). Any idea why?
Additionally, I looked around but could not find good documentation about the boundaryRadiationProperties. Especially about the different types (opaqueDiffusive vs opaqueReflective) and why the absorptivity and emissivity are defined by two floats. (In the example (0.3 0.7)). Any idea where I can get information about this? EDIT : Maybe regarding the limitT, I found a weird issue. At the beginning of my log, I get the sentence: " Selecting finite volume options type limitTemperature Source: limitTAir - selecting all cells - selected 34761 cell(s) with volume 39.8291 " But it seems that, looking at paraview, my mesh is made of 89843 cells and 51980 points ?! Last edited by Hawxliquid; August 18, 2023 at 05:12. Reason: extra info |
August 18, 2023, 05:32 |
#6 | ||
Yann
Rep Power: 27 |
If information is not available in the documentation, you have to search into the source code: Code:
grep -r "opaqueDiffusive" $FOAM_SRC You can check the file header to hopefully gather information about it, and if this is not enough you'll have to dig into the code itself, which might be pretty tedious. Note that this is only and example, you can also use find to search for specific files and directories, while grep will search a pattern into files. It can be interesting to use both, depending on the situation. In addition, you might find interesting things in the release notes. For instance the initial release of solarLoad: https://www.openfoam.com/news/main-n...ical-modelling There must have been some additions in the next releases. I find radiation models in OpenFOAM pretty messy, good luck getting your way through the jungle! Yann |
August 18, 2023, 05:36 |
#7 | |
Yann
Rep Power: 27 |
Cheers, Yann |
August 21, 2023, 04:14 |
Boris
Rep Power: 9 |
Thank you so much for all the information Yann, they are very useful!
I manage to make the simple case work, but not the case I want to apply it to. I have been trying for a while to find where my error could arise from, but to no avail. When I launch the case (even with radiation turned off), my velocity diverges, as shown here : https://pastebin.com/23G5mQ6w I also see at the first iteration that the enthalpy equation seems to diverge, right at the start? Why would that happen? (DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 78.6652, No Iterations 1000) For information, my fvSolution : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver PCG; preconditioner DIC; tolerance 1e-08; relTol 0.01; } "(U|h|k|epsilon)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 0.05; } } SIMPLE { nNonOrthogonalCorrectors 10; rhoMin 0.5; rhoMax 2.0; residualControl { p_rgh 1e-2; U 1e-4; T 1e-2; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p_rgh 0.3; p 0.3; U 0.7; T 0.7; } equations { U 0.3; T 0.3; "(k|epsilon|R)" 0.2; rho 0.3; } } // ************************************************************************* // fvSchemes : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; energy bounded Gauss upwind; div(phi,h) $energy; div(phi,K) $energy; turbulence bounded Gauss upwind; div(phi,k) $turbulence; div(phi,epsilon) $turbulence; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.333; } interpolationSchemes { default linear; } snGradSchemes { default limited corrected 0.333; } fluxRequired { default no; p_rgh; } // ************************************************************************* // If anyone had any idea of why this happen, that would be very useful! Thanks EDIT: It seems like that my issue comes from my pressure and p_rgh BC. But I can't seem to find how to fix it. I have an open domain (dome_big), and my BC are: p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { #includeEtc "caseDicts/setConstraintTypes" ".*" { type calculated; value $internalField; } } // ************************************************************************* // prgh Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { dome_big { type prghTotalPressure; p0 $internalField; } ground { type fixedFluxPressure; value $internalField; } buildings { type fixedFluxPressure; value $internalField; } water { type fixedFluxPressure; value $internalField; } } // ************************************************************************* // |
August 21, 2023, 05:24 |
#9 | |
Yann
Rep Power: 27 |
DILUPBiCGStab: Solving for h, Initial residual = 0.580014, Final residual = 0.0151477, No Iterations 4 (By the way, you can monitor residual by plotting it, it makes it easier to follow what's going on in the simulation. I would also recommend to plot variables of interest such as min/max temperature, max velocity, etc...) Back to your diverging velocity: it can be VERY tricky to find proper boundary conditions for buoyant flows, especially for open domains. When dealing with natural convection, the flow conditions at the boundaries are usually not known and the flow is driven by buoyant forces inside the domain. Numerically speaking, this is not something easy to deal with. I personally still don't have reliable set of boundary conditions for such cases. You can have a look at this thread which basically discuss this matter: Common setup for p_rgh in complete open domains Another recommendation: try avoiding 1st order schemes when it comes to natural convection. It can lead to weird stuff like reversed convection flow. Aside from numerical schemes, I think your main challenge will be to find a proper set of boundary conditions for your case. Good luck! Yann |
August 22, 2023, 04:43 |
#10 | |
Boris
Rep Power: 9 |
Again, merci for your time and such great information! I think I am starting to get a okay convergence. If anyone is interested, previously my " far field" model was made of the side and the sky as the same patch, hence making the convergence problematic regarding BC. I separated the two, and used a prghTotalPressure for the "sky", and fixedFluxPressure on the rest of the BCs. That seem to work so far. Now, just have to play with the radiation model to get "realistic" temperature on the BCs! Currently they reach thousands of K, for a qr equivalent to a sunny day |
Continuity divergence in simple gas flow | Okka | FLUENT | 7 | January 11, 2019 01:01 |
compressibleInterFoam incl. viscous dissipation heating | vigges | OpenFOAM Programming & Development | 5 | June 10, 2018 06:06 |
SIMPLE vs. PISO | Kappa | OpenFOAM Running, Solving & CFD | 1 | October 17, 2016 08:08 |
problem simulating an advection equation | hami9293 | Main CFD Forum | 1 | July 17, 2015 16:01 |
SIMPLE algorithm | Jonathan Castro | Main CFD Forum | 3 | December 10, 1999 04:59 |
