Modelling thin filter in channel flow (2D)
Like Tree1Likes
  • 1 Post By K-al-Eps-o
Old   August 8, 2023, 06:05
Lightbulb Modelling thin filter in channel flow (2D)
Baptiste
K-al-Eps-o is on a distinguished road
I want to study the boundary layer intereaction with filter (thin mesh fabric in my experimental setup) inside a square duct (e.g bounded boundary layer flow).
I started with a 2D rectangular domain with a cellZone and faceZone used with the "Change flow direction" source term to model the filter. Even though this model allows to specify a pressure drop, the user can only specify a unique fixed flow angle at exit, but it doesn't make a lot of sense.
In fact, I would like to implement a refraction angle i.e a local outlet angle, function of the local filter inlet angle.
Is there a way to do it with this source term?
Would it be possible to change the source code to allow this?
Would another source term be more suited ?
Any comment would be much appreciated
raj kumar saini likes this.
K-al-Eps-o is offline   Reply With Quote
boundary layer flow, filter, refraction, source terms
LES Setup of a cyclic channel flow for compressible solver Phil910 OpenFOAM Running, Solving & CFD 3 November 14, 2024 08:42
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
Constant mass flow rate in channel flow LES vishwesh OpenFOAM Running, Solving & CFD 4 May 10, 2018 10:10
[General] Mass Flow Using Surface Flow Filter Incorrect t8fanning ParaView 1 March 13, 2017 06:56
