rhoPimpleFoam does not work with higher velocity
Like Tree2Likes
  • 2 Post By Swirl
Old   June 29, 2023, 12:36
Default rhoPimpleFoam does not work with higher velocity
Lukas
Lukas1 is on a distinguished road
Hello everyone,
I´m quite new to OpenFOAM and have a problem with rhoPimpleFoam.
The case is a 3D pipeline with a orifice and a vessel at the end of the pipeline. The excitation is a sinusoidal excitation of velocity (mean flow 10 m/s) with an amplitude of 10 m/s and a frequency of 40 Hz. The aim is to evaluate the pressure fluctuations. The pipeline is splitted in the middle to use symmetry (xyplanes are symmetry planes). (see model in geometry.jpg)
When I start the simulation it stops after about 0,1 s of simulation and there comes the error message which can be seen in error.jpg. The final residual rises to a very high value. Moreover there are strong fluctuations behind the orifice which not really makes sense (see fluctuations.jpg). The turbulence model I use ist k omega SST. The medium is air (atmospheric pressure at outlet).
I tried the exact same simulation with a mean flow of 5 m/s, an amplitude of 5 m/s and a frequency of 40 Hz. This simulation runs normally and gives reasonable results. Can someone maybe tell me why the simulation with rhoPimpleFoam works for 5 m/s mean flow velocity but not for 10 m/s?
0/U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
		type			uniformFixedValue;
		uniformValue	sine;
		uniformValueCoeffs
			frequency	40;
			amplitude	10;
			scale 		(1 0 0);
                        level 		(10 0 0);
			t0  		0;
    outlet
        type            zeroGradient;
	xyplane
        type            symmetry;
    wall
        type            noSlip;
	wallrefine
        type            noSlip;
	xyplanevessel
        type            symmetry;
	vessel
        type            noSlip;
0/p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 101325;
	xyplane
        type            symmetry;
    wall
        type            zeroGradient;
    wallrefine
        type            zeroGradient;
	xyplanevessel
        type            symmetry;
	vessel
        type            zeroGradient;
	#includeEtc "caseDicts/setConstraintTypes"
0/T:
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 293;
    outlet
        type            zeroGradient;
	xyplane
        type            symmetry;
    wall
        type            zeroGradient;
	wallrefine
        type            zeroGradient;
	xyplanevessel
        type            symmetry;
	vessel
        type            zeroGradient;
0/omega:
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 25.88;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 25.88;
    outlet
        type            zeroGradient;
	xyplane
        type            symmetry;
    wall
        type            omegaWallFunction;
    wallrefine
	xyplanevessel
        type            symmetry;
	vessel
0/k:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.375;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.375;
    outlet
        type            zeroGradient;
	xyplane
        type            symmetry;
    wall
        type            kqRWallFunction;
    wallrefine
	xyplanevessel
        type            symmetry;
	vessel
0/nut:
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
	xyplane
        type            symmetry;
    wall
        type            nutkWallFunction;
        value           uniform 0;
    wallrefine
        value           uniform 0;
	xyplanevessel
        type            symmetry;
	vessel
        value           uniform 0;
controlDict:
application     rhoPimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         1;
deltaT          0.0001;
writeControl    adjustable;
writeInterval   0.002;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           5;
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)       Gauss upwind;
    div(phi,k)       Gauss upwind;
    div(phi,omega)   Gauss upwind;
    div(phi,nuTilda) Gauss upwind;
    div(phi,R)       Gauss upwind;
    div(R)           Gauss linear;
    div(phi,e)      Gauss upwind;
    div(phi,K)      Gauss upwind;
    div(phi,Ekp)    Gauss upwind;
    div(phiv,p)     Gauss upwind;
    div((phi|interpolate(rho)),p)  Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method          meshWave;
fvSolution:
solvers
    "pcorr.*"
        solver          GAMG;
        tolerance       1e-2;
        relTol             0;
        smoother        DICGaussSeidel;
        cacheAgglomeration no;
        maxIter         50;
	p
        $pcorr;
        tolerance        1e-6;
        relTol           0.01;
    pFinal
        $pcorr;
        tolerance        1e-6;
        relTol           0;
    "(U|k|omega|R|nuTilda|e|rho)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0.1;
    "(U|k|omega|R|nuTilda|e|rho)Final"
        $U;
        relTol          0;
PIMPLE
    nNonOrthogonalCorrectors 1;
    nCorrectors         2;
Thanks for your help!
Lukas
Lukas1 is offline   Reply With Quote
Old   July 5, 2023, 12:09
Swirl is on a distinguished road
from what you posted, I can see two things you may try.
1) reduce the maxmimum Courant number in your controlDict. rhoPimpleFoam does work with values larger than 1, but in any case it is a good idea to keep them below 1.
2) Try to use a waveTransmissive BC for the pressure field at your outlet. Since you are actively trying to generate pressure fluctuations, the fixed value BC at the outlet could be a problem. There is an explanation of how to use it under the link below.
https://openfoamwiki.net/index.php/H...dary_condition
Please let me know if this works.
dlahaye and hogsonik like this.
Swirl is offline   Reply With Quote
Old   July 5, 2023, 17:31
Domenico Lahaye
dlahaye is on a distinguished road
Agree to waveTransmissive BC.
We succesfully applied them in https://www.mdpi.com/2311-5521/7/6/205
I am interested in seeing how it works for you.
dlahaye is offline   Reply With Quote
Old   July 6, 2023, 09:52
Lukas
Originally Posted by Swirl View Post
Thank you! I reduced the maxCo to 1 and now the simulation works!
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Viscous Work in rhoPimpleFoam (OF 1612) L_W OpenFOAM Programming & Development 1 August 1, 2018 11:56
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain sdfij6354 OpenFOAM Running, Solving & CFD 3 July 26, 2017 17:16
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
