Specifying water phase diameter in reactingMultiphaseEulerFoam
Like Tree1Likes
  • 1 Post By sinhavivekananda318
Old   June 28, 2023, 15:54
Default Specifying water phase diameter in reactingMultiphaseEulerFoam
Vivekananda
sinhavivekananda318 is on a distinguished road
Hello all,
I am trying to do bubble column simulation in reactingMultiphaseEulerFoam of openfoam 7. In that the default water phase dia is 1e-4 and air phase dia is 3e-3 m. If I give water phase dia 1 and keep the blending as none and continuous Phase as water, the simulation diverge.
However, in multiphaseEulerFoam in openfoam 5, I ran the simulation successfully with the above-mentioned values
I understand that that if I equate surface tension force and buoyancy force then for a nozzle dia of 1 mm , the air phase dia comes out as 3.73e-3 m. Can you please help me in the logic of selecting water phase dia as default 1e-4 m.
Also can you guide me as to select the parameters in the phase properties so that I can run my simulations with air dia as 3e-5 and water dia as 1 keeping the interphase compression 1.
I have a hunch that it might related to the blending and selection of drag model.
Any help would be much appreciated.
BIRAJ likes this.
sinhavivekananda318 is offline   Reply With Quote
blending function, bubble column, drag laws, reactingmultiphasefoam
phase diameter and phase compressibility in multiphaseEulerFoam solver mike.franky OpenFOAM Running, Solving & CFD 7 May 20, 2020 10:45
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 08:01
Discontinuity at water level in stratified 2 phase flow kbaker CFX 24 June 14, 2012 08:37
I want to rotate secondary phase (bubble in water tank) huseyin Fluent UDF and Scheme Programming 0 May 5, 2010 04:00
