ChtMultiRegionFoam boudary condtion solid-solid |
June 15, 2023, 12:57 |
Rachele Zamboni
Rep Power: 3 |
Hellow everyone!
I am currently working on a multiregion simulation to study the heat transfer between different region wiht solver chtMultiRegionFoam. Inside my domain I have both interfaces between solid and fluid regions but also between two solids. Currently I am imposing at each interface between regions the boundary condition for temperature : solid1_to_solid2 { type compressible::turbulentTemperatureCoupledBaffleMix ed; value $internalField; Tnbr T; } Unfortunately with this condition I am not able to correctly solve the problem and for even very simple meshes, If I simulate the interaction between solid regions after some iterations I get a negative T. More over before the negative T, the temperature fields between region is not consistent with my input. I think that it could be a problem with this boundary condition. Does anyone have solved conduction between solids with chtMultiRegion with another BC? |
June 17, 2023, 13:18 |
Peter Hess
Rep Power: 17 |
Hello!
kappaMethod could be missing. type compressible::turbulentTemperatureCoupledBaffleMix ed; Tnbr T; kappaMethod solidThermo; value $internalField; Be also sure, that in constant\regionsProberties all the solid regions are defined as solid. Tutorial heatedDuct is a good example and it includs solid to solid interface. Take the solver setups from this tutorial. Last edited by peterhess; June 18, 2023 at 00:08. |
boundary condition, chtmultiregionfoam, solid conduction, solid interface |
How to implement radiation between a porous and a solid region in chtMultiRegionFoam? | ThunderstruckGER | OpenFOAM Running, Solving & CFD | 1 | November 17, 2023 00:00 |
chtMultiRegionFoam connection between solid and fluid region of heat exchanger | ahab | OpenFOAM | 1 | December 18, 2019 01:37 |
Immersed Solid and FSI | Pierrm | CFX | 0 | March 26, 2018 06:36 |
defining solid and fluid in chtMultiregionFoam | R_21 | OpenFOAM Running, Solving & CFD | 2 | July 1, 2015 11:54 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
