Tempearture discontinuity among regions
Like Tree1Likes
  • 1 Post By Alczem
Old   June 12, 2023, 12:07
Default Tempearture discontinuity among regions
TGS
TGS
TGS is on a distinguished road
I want to analyses the heat transfer of a fin with a side which is heated upto a constant temperature of 400K. The fin was surrounded by the air which was initially at 300 K. I used chtMultiRegionFoam solver and the simulation was performed without any error. However, as shown in the screenshot of temperature distribution, there is a temperature discontinuity in between regions. To get a temperature distribution over the inter region, do you know what I can do? Do I need to make the mesh finer than this? Or do I need to add kappa Method under the turbulentTemperatureCoupledBaffleMixed function in T? or else, is it ok to add fvmodels of inter region heat transfer to each three regions? .
My T file for air is as follows.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0/air";
object T;
dimensions [ 0 0 0 1 0 0 0 ];
internalField uniform 300;
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
inlet
type fixedValue;
value $internalField;
outlet
type inletOutlet;
inletValue $internalField;
top
type zeroGradient;
bottom
type zeroGradient;
frontAndBack
type zeroGradient;
air_to_fin
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
air_to_heatedBoundary
Tnbr T;
and T file for fin:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0/fin";
object T;
boundaryField
fin_to_air
Tnbr T;
fin_to_heatedBoundary
Tnbr T;
top
type zeroGradient;
bottom
type zeroGradient;
frontAndBack
type zeroGradient;
inlet
type zeroGradient;
outlet
type zeroGradient;
and T file for heated Boundary
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
location "0/heatedBoundary";
object T;
internalField uniform 400;
boundaryField
heatedBoundary_to_air
Tnbr T;
heatedBoundary_to_fin
Tnbr T;
top
type zeroGradient;
bottom
type zeroGradient;
frontAndBack
type zeroGradient;
inlet
type zeroGradient;
outlet
type zeroGradient;
2. Though the velocity distribution shows the air flow over the fin, I can’t see the inlet velocity value of 5 m/s for Z direction in legend. The values are seeming not sensible. So, do you know what is the reason behind that? my U file is as follows.
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0/air";
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (0 0 5);
boundaryField
inlet
type fixedValue;
value uniform (0 0 5);
outlet
type inletOutlet;
inletValue uniform (0 0 5);
top
type noSlip;
bottom
type noSlip;
frontAndBack
type zeroGradient;
air_to_fin
type noSlip;
type noSlip;
Can anyone please help me. I am new to OpenFOAM and this is my first simulation.
Thanks,
TGS
TGS is offline   Reply With Quote
Old   June 13, 2023, 09:02
Alczem is on a distinguished road
Hey!
It is not impossible that the result you shared is actually correct. The air could be slightly heated near the fins, but the scale rnging from 300 to 400 kelvins prevents you from seeing this. Try to lower the upper bound of your colorscale just to make sure it is not an issue of visualisation.
If you see the air being slightly hotter near the fins, then it is just a matter of how much heat is exchanged, and you could try to lower the air inlet velocity so that the air has more time to heat up.
Check if your thermophysicalProperties have sensible values, especially kappa and Cp. The turbulence model also has an impact.
TGS likes this.
Alczem is offline   Reply With Quote
Old   June 13, 2023, 09:20
TGS
TGS
Dear Alczem,
Thank you very much for your prompt answer and I will make the changes that you asked to my simulation and check it again.
Once again thanks a lot.
Thanks,
TGS
Old   June 15, 2023, 06:42
TGS
TGS
Dear Alczem,
I managed the results with the velocity and it was a problem with the legend in colour map. and temperature variation can be seen when the range is reduced. Thank you very much for the help
Thanks,
TGS
chtmulitregionfoam, heat balance, opeanfoam
[snappyHexMesh] Multi-region meshing produces too many regions efalpha OpenFOAM Meshing & Mesh Conversion 1 June 6, 2023 04:23
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall JayDeeUU OpenFOAM Pre-Processing 16 July 22, 2021 22:17
[CAD formats] Clean / Repair STL file with multiple regions on command line matthiasd OpenFOAM Meshing & Mesh Conversion 6 May 24, 2016 07:51
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
chtMultiRegionFoam different properties in (fluid) region(s) volker1 OpenFOAM Pre-Processing 3 February 4, 2015 07:46
