Is there a compressible phase changing solver with sharp interface? |
June 8, 2023, 03:00 |
Is there a solver that can handle 4 phases, compressible (high Mach numbers) with phase change (melting and solidification) and sharp interface (droplet particle dynamics is important) between liquid and solid phase in OpenFOAM?
multiphaseEulerFoam seems to come close and seem to have VOF sharp interface capabilities but how do I activate that between two phases? Also, will the saturation pressure/temperature conditions be right for melting/solidification in multiphaseEulerFoam? Also, how do I apply a temperature-based heat source in fvOptions in multiphaseEulerFoam? Alternatively, is there a compressibleInterFoam solver with phase change? Thanks! |
June 8, 2023, 05:38 |
Rep Power: 5 |
Hey!
As you said, multiphaseEulerFoam is the closest solver with the features you need IMO. I think it can handle phase changes with interfacialProperties. You can set interfaceCompression in transportProperties to have sharp interface between phases. For the heat source, maybe try this: https://www.openfoam.com/documentati...-implicit.html You may need to test different settings to properly use it though, I don't know how it works in multiphase solvers. Keep this thread update, I would be interested to know about the setup files if you manage to run your simulation |
September 8, 2024, 13:29 |
Thermal shrinkage of PCM during solidification
#3 | |
JANGA RAKESH KUMAR
Rep Power: 2 |
Hello Alczem, I want to model solidification in which air phase is there initially at top of liquid. so, when solidification progresses, the shrinkage void forms. Many threads are discussing about pure solidification where density is same for liquid and solid. However, in my case densities are different for liq and solid. Also need to include third phase air. I tried using InterCompressible but unsuccessful. I dont no how to include interform for solidification. Do you know how this problem can be setup in openFOAM?? Any suggestion and help for this problem is greatly appreciated. Thanks in advance -Rakesh |
compressible euler, multiphase flow, openfoam |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Paid Work: Compressible Two Phase Flow Solver | AnasCFD | CFD Freelancers | 0 | July 12, 2015 12:21 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
