runApplication: command not found
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By sstevenson638
Old   June 7, 2023, 17:07
Default runApplication: command not found
Scott Stevenson
sstevenson638 is on a distinguished road
I'm new to OpenFOAM and am running through the tutorials. I am currently trying to step through the Allrun script of the DTCHull tutorial by running each command outside of the script. When I get to a loop Allrun I made a snippet out of it that looks like this:
#!/bin/bash
for i in 1 2 3 4 5 6
do
runApplication -s "$i" \
topoSet -dict system/topoSetDict.${i}
refineMesh -dict system/refineMeshDict -overwrite
done
It gives the error runApplication: command not found.
Can anyone help? I've looked everywhere for how or where where runApplication is defined but can't find it anywhere. I used to know unix but I haven't worked in that environment for 20 years.
Thanks in advance.
PS: I'm running under WSL on Windows 10.
Last edited by sstevenson638; June 7, 2023 at 17:11. Reason: Added additional info about environment
sstevenson638 is offline   Reply With Quote
Old   June 7, 2023, 18:22
Yann
Yann will become famous soon enoughYann will become famous soon enough
If you look at the beginning of the Allrun script, you will see something like this:
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
This line loads RunFunctions, and runApplication is one of those functions.
If you want to use RunFunctions in your script, you will need to use this line to load it.
Cheers,
Yann
sstevenson638 likes this.
Yann is offline   Reply With Quote
Old   June 8, 2023, 13:34
Scott Stevenson
Thank You! I knew it had to be something like that I was missing.
Yann likes this.
dtchull tutorial, runapplication
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
