PythonFOAM parallel run
Like Tree1Likes
  • 1 Post By pbevington
Old   May 24, 2023, 11:15
Default PythonFOAM parallel run
Nasrin Sahranavardfard
Nasrin Fard is on a distinguished road
Hi all,
I am using Python and numpy libraries inside OpenFOAM, and I use a Python module to calculate density instead of rho = thermo.rho() whatever we have that in reactingFoam solver. I had to define objects and arguments to make the module readable. for running an OpenFOAM code in parallel, I use the following command "mpirun -np 2 reactingFoam -parallel", but it doesn't work for the PythonFOAM case. and I see the following error,
"mpirun noticed that process rank 0 with PID 0 on node BOOK-SK5J7CQPFM exited on signal 11 (Segmentation fault)."
did you have any experience with parallel running?
Nasrin Fard is offline   Reply With Quote
Old   May 30, 2023, 18:17
Peter Bevington
pbevington is on a distinguished road
Have you tried running in serial? Does it only fail when running in parallel?
What does your parallel setup look like? Do you have a decomposeParDict?
Nasrin Fard likes this.
pbevington is offline   Reply With Quote
Old   May 30, 2023, 18:23
Thanks pbevington for your reply. I can run it in serial without any problem. For parallel running I do decomposePar first and after that mpirn...but it doesn't work. Maybe it is related to the ranks, but I don't kmow what should I do exactly.
The problem when i use parallel computation for mesh deforming. Hiroaki Sumikawa OpenFOAM Running, Solving & CFD 0 November 20, 2018 03:58
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 12:05
User fortran to input/output file in a parallel run doublestrong CFX 5 March 31, 2017 09:15
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 15:43
