May 22, 2023, 06:43 |
icoFoam - Fields don't match error
Rep Power: 3 |
Hello folks.
I am a new Openfoam user. I am trying to do a paralllel simulation for flow around shampoo bottle in an arbitrary Initial orientation. The solver is IcoFoam. The mesh looks fine coz, although checkMesh allGeometry -allTopology gave 2 Mesh Checks, the coupled mesh point average Seems okay... and the Non orthogonality check is Passed. However, upon the running the simulation, I get the error Mesh/fields don't match. I am attaching the controlDict, snappyHexMeshDict, blockMeshDict Files, checkMeshlog, icoFoamlog as well as the screenshot of the error... Any help will be highly appreciated. |
May 22, 2023, 07:44 |
Yann
Rep Power: 27 |
Can you describe what exact commands you are running and in which order ? Regards, Yann |
June 1, 2023, 10:39 |
Rep Power: 3 |
Hello Yann,
I executed the commands in the following sequence: 1) I first run blockMesh on a 1 x 1 x 3 meter grid with 50 x 50 x 150 cells, then 2) surfaceFeatures, then 3) decomposePar with hierarchical decomposition of n (1 2 2) order zxy, then 4) snappyHexMesh () on 4 procs, enabled with explicit Feature Edge refinement, surface-based refinement, region-wise refinement, surface snapping and layer additions, followed by checkMesh -allGeometry -allTopology, and finally, recomposePar. After manually inspecting the mesh for the indicated failed mesh checks (lowQualityTetFaces 9), I felt the mesh was still OK enough to run the simulation. Hence, I run icoFoam on 4 procs (see attached icoFoamlog_v1). The solution seems to be converging I think, coz the time step continuity errors (sum local) are of the order of 10^(-9). However, at the end of the simulation, when I load the time steps in paraView, it is giving me the error seen in the screenshot. |
June 1, 2023, 11:18 |
Yann
Rep Power: 27 |
OK thanks for the inputs. Your error message complains about a mesh size mismatch. When running snappyHexMesh, it creates new timeStep folder to store the mesh (one folder for each meshing steps: castellated, snap, layers) After meshing you will have to move the polyMesh directory from the last time step into the constant folder so icoFoam will load this mesh and run on it. You can also run snappyHexMesh with the -overwrite option to write mesh directly into constant rather than creating new time steps. If you didn't use the overwrite option nor have moved the final mesh into constant, this is very likely the reason for this error message. Hope this helps, Yann |
June 2, 2023, 01:12 |
Rep Power: 3 |
Hello Yann,
Thanks for your swift response. I thought that this operation was done by the reconstructPar command. which I did after meshing as well as running icoFoam. |
June 2, 2023, 03:34 |
Yann
Rep Power: 27 |
Looks like you didn't post the whole commands you've been running since you didn't mention reconstructPar before. I'm a bit insistent on this because details are important in a simulation workflow. Small detail on one command is enough to mess with the whole process. Generally speaking, OpenFOAM commands tend to avoid overwriting data unless otherwise specified. If you ran snappy without the overwrite option, reconstructPar should just reconstruct the time step directories containing the meshes without touching the original constant/polyMesh directory (which contains the mesh created by blockMesh). Unless you used some options with reconstructPar? I'm not sure there is such option but to be fair I never use reconstructPar anyway. |
June 15, 2023, 07:13 |
Rep Power: 3 |
Hello Yann,
Sorry again for the long gap in responding. Answering your question, no, I didn't use the -overwrite flag in snappyHexMesh, nor did I use any options with reconstructPar. I will try the simulation again with your suggestions and get back to you, hopefully sooner this time 😅 Edit (3 hours later) ------------------------------------------------------------------------------------------------------------------------- Hello again Yann, First I manually pasted the content of the polyMesh folder for the last timeStep (in my case 0.11) directory into the constant/polyMesh and run icoFoam. I even replaced the boundary, faces, neighbour, owner, points files with the ones from the last timeStep. So when I run icoFoam again, it gave an error in cells 262701 (<large tuple of numbers>) there are no cells of level 8 or below . Please be advised that I was attempting this as a frivolous trial run, so I didn't save the log file for this error, and I am paraphrasing the error from memory. Then I thought, let's rerun snappyHexMesh and try again, but of course, it gave me a "?libc (core dumped)" error, but I kinda expected it to not work coz I had overwritten the blockMesh boundary, faces etc. files. I cleaned the entire case, reran the entire simulation workflow again, but this time with the reconstructPar -latestTime option, which should perform the same function that you advised. After everything, the simulation is converging, but it is giving the exact same error still, so, I am back at square one as of now. 😅😅 Any help greatly appreciated, Kind Regards, - Harshawardhan Patil Last edited by baldbrain; June 15, 2023 at 10:20. |
June 18, 2023, 12:42 |
Yann
Rep Power: 27 |
What do you mean by "simulation is converging" ? Like, icoFoam is running and crash with this message after solving some time steps? Regards, Yann |
June 20, 2023, 21:05 |
#9 |
Rep Power: 3 |
Hello Yann,
No, the simulation seems to be running perfectly fine till the end, with acceptably small residuals. Please check the icoFoamlog attached in this message. I have zipped it because the original log filesize was exceeding the limit. The zip file was scanned with Bitdefender Internet Security and reported no threats 👍 |
June 21, 2023, 03:18 |
#10 |
Yann
Rep Power: 27 |
Your log looks like you ran icoFoam in parallel without the -parallel option. (which actually just run n serial icoFoam processes rather than running icoFoam in parallel)
The proper command should be something like: Code:
mpirun -np 4 icoFoam -parallel Code:
runParallel icoFoam |
June 21, 2023, 14:33 |
#11 |
Rep Power: 3 |
Hello Yann,
Thanks or pointing that out. I reran the simulation with the right command, and here's the new icoFoam log. Also attached is the reconstructPar -latestTime log that I ran afterward the simulation. I'm afraid it's still the same issue Last edited by baldbrain; June 21, 2023 at 14:34. Reason: zip file not attached |
June 22, 2023, 03:04 |
#12 |
Yann
Rep Power: 27 |
That's better! Not sure how you made your log file but it seems the error does not show in the log you've posted. Now, if you meshed your case in parallel, you need to reconstruct the mesh before reconstructing the field. Try running these commands, in this order: Code:
reconstructParMesh -constant reconstructPar -latestTime Yann |
July 10, 2023, 23:21 |
#13 |
Rep Power: 3 |
Hello Yann,
I'm once again sorry for not reverting back to you soon. My account was disabled by the moderators. But the issue seems to have resolved now. Are you still available to help me on this problem? Regards, - Harshawardhan |
July 11, 2023, 13:27 |
#14 |
Yann
Rep Power: 27 |
Sure, but what's your problem since you say it's been resolved?
July 22, 2023, 01:32 |
#15 |
Rep Power: 3 |
Well at first, I thought it was because I posted external links in a separate post. But later I discovered that I had changed the email for my account, and apparently we have to reactivate our account every time we change the email.
field for p, icofoam -parallel, icofoam problem, solver error |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
