fvModels-accelerationSource - No velocity change
Like Tree2Likes
  • 2 Post By JNSN
Old   May 4, 2023, 03:15
Unhappy fvModels-accelerationSource - No velocity change
Desh
dasith0001 is on a distinguished road
Hi Foamers,
I am trying to simulate an effect of fan, and I am using ''accelerationSource'' fvModel. I am using OpenFoam10
The fvModel works fine if I include 'halfCosineRamp' but I cannot see any changes to velocity field when I change it to ''constant''.
I am assuming the fan would exert a constant acceleration to the fluid. Would you take a look into the file ?
PHP Code:
accelerationSource1
type            accelerationSource;
selectionMode   cellZone;
cellZone        rotor;
U               U;
velocity        scale;            //constant; //uniform;
value           (0 0 10);
scale
type         constant;     //one;  //halfCosineRamp;  //constant;
                                      //halfCosineRamp; uniform constant
value        1;
//start           0;
        //duration        100;
Also, is this the 'right' fvModel to simulated the 'effect of the fan' ?
Thank you
Dasith
dasith0001 is offline   Reply With Quote
Old   May 4, 2023, 10:18
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Dasith,
the accelerationSource does not have any effect when using constant as scaling function. Having a look at the code you can see, that the acceleration is calculated by the difference of velocity between the time steps:
const vector dU =
        velocity_->value(mesh().time().timeToUserTime(t))
      - velocity_->value(mesh().time().timeToUserTime(t - dt));
 const vector a = dU/mesh().time().deltaTValue();
which gives zero acceleration for a constant scale.
I suggest you have a look at the actuationDiskSource in order to model the effect of a fan.
Best,
Jan
JNSN is offline   Reply With Quote
Old   May 4, 2023, 20:37
Smile
Desh
Hi Jan,
Thank you very much for the response.
ok, it makes sense now.
Hmm, I've been looking into actuationDiskSource as well, but is it not something to be use for a turbine, where the rotor is driven by wind? fan, is other way around.
PHP Code:
rotor
type            actuationDiskSource;
active          on;
cellZone        rotor;
actuationDiskSourceCoeffs
cellZone        rotor;
fields          (U);        // names of fields to apply source
diskDir         (0 0 1);   // disk direction
Cp              0.9;        // power coefficient
Ct              0.9;        // thrust coefficient
diskArea        0.00001;        // disk area
upstreamPoint   (0.65 0 1.82);    // upstream point
There is thread on this, but that either do not explain much,
Basic use of actuationDiskSource
And this'' Changing rotorDiskSource from source to sink '' also suggest actuationDisk might behave as a turbine.
'rotorDisk' might be my only option?
It is very hard to find any explanations/clarity of on OpenFOAM fvModels/fvOptions in general, whilst those remains very important. I would really appreciate if anyone could shred more light
Thank you
Dasith
Old   May 9, 2023, 05:51
JNSN's Avatar
Jan
Hi, I have never used the OpenFOAM Implementation. But for my understanding the actuationDisk acts Like a driven Propeller, e.g. behind a ship. That means the flow is accelerated die to the implied thrust of the Rotor.
Yann and dasith0001 like this.
accelerationsource, fvmodels
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 09:56
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Change in velocity at inlet mutewinter Main CFD Forum 0 June 6, 2014 07:01
mean velocity change from inlet to outlet ro FLUENT 2 April 19, 2008 14:37
