Running high non orthogonality mesh
Like Tree1Likes
  • 1 Post By pferro
Old   May 1, 2023, 06:08
Default Running high non orthogonality mesh
Marco Carbotta
MCRB8 is on a distinguished road
Hello everyone, I'm trying to run a polyheadral mesh from a commercial mesher in OpenFOAM with chtMultiRegionSimpleFoam, but given the nature of the mesh it's very unstable and the simulation diverges, the max non orthogonality of the mesh is 98 and there are 16627 faces with orthogonality over 70, am I just wasting my time trying to run this?
I tried running simpleFoam and then switching to chtMultiRegionSimpleFoam but as soon as I run a few steps with cht the k and epsilon values explode and so does the temperature (I think it's a problem with the solving of p).
I tried lots of different schemes and I'm using the following relaxation factors:
p_rgh and p= 0.3
k and epsilon= 0.5
h=0.9
U=0.5
I know I'd need a better mesh but it's really hard to get one, does it make sense to even try or will it never give me results that make sense? I'll attach the checkMesh for reference
Thanks in advance for any response, it will sure ease my day
MCRB8 is offline   Reply With Quote
Old   May 1, 2023, 09:31
Kuzey Can Derman
NorthCFD is on a distinguished road
You can use nNonOrthogonalCorrectors in fvSolution if you haven't already. It helps to solve meshes with high orthogonality. In your case you should run a high number of loops but you will find the exact number by experimenting yourself, start with 3 and increment it.
But this is not a definite solution, you have a very high orthogonality mesh, it may not work.
Btw it looks like you have other mesh problems like open cells, they may cause problem too, can you use "checkMesh -latestTime -meshQuality -allTopology -allGeometry" and post the output?
NorthCFD is offline   Reply With Quote
Old   May 1, 2023, 16:27
Marco Carbotta
Hey, thanks for the answer
I've been using a nonorthogonal corrector value of 3 but I've read that after that it doesn't matter too much so I left it there, I tried running with 4 and 5 but still no luck, I'll test with higher values, thanks for the suggestion.
Here is my full checkmesh file, as you said I do have some open cells, but I've also checked an older version of the mesh before trying to "repair" it and that one doesn't have open cells but has an even higher non-ortho.
I'm also uploading my fvSchemes in case I could be doing something better there, I'm trying to run with first order schemes at first for more stability and change to second order later.
Old   May 2, 2023, 15:41
Paulin FERRO
pferro is on a distinguished road
Give up if you have max non-ortho > 90 and remesh.
By the way nNonOrthogonalCorrectors is from my experience not the best way for dealing with high non ortho cells (1 or 2 iterations is fine).
The good way is to limit the non orthogonal correction for laplacian schemes.
Still from my experience, it would be preferable to have your max non ortho < 85.
Sakun likes this.
pferro is offline   Reply With Quote
chtmultiregionfoam, non orthogonal, schemes
[snappyHexMesh] cracks running through mesh DeGeorg OpenFOAM Meshing & Mesh Conversion 1 July 31, 2020 18:08
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
